P1000 Heater core bypass valve
Hawk53
Hawk53
485
622
Alberta Canada
Is there anyone with a Pioneer 1000 that has a honda heater and installed a heater core bypass valve? If so do you have a brand/part number for the valve?
Hawk53
Hawk53
485
622
Alberta Canada
read through this thread, lots of good info there
Thanks but didn't see anything about a heater core bypass valve.
john790
367
1,105
Clinton ohio 44216
Well heres my take on this.If i was going to bypass the heater core i would make my own using ball valves.All most never leak easily found and brass fittings.The reasons i did'nt do that.1 you trap old antifreeze in the core.2 you have a extra rad if needed if stuck out somewere over heating turn the fan on might get you home while very uncomfortable i understand.Beats walking.In the summer i plug my ducts with foam to knock down the heat easy to remove if needed.
Hawk53
Hawk53
485
622
Alberta Canada
T
Thanks for your input.
Reactions: Lady01 and ChadD
Hawk53
Hawk53
485
622
Alberta Canada
This is what I am after. Amazon doesnt have it right now and other suppliers are up to 3 times the cost.
4FE13C40 DD66 44FF AD52 52607F9A5D7B
slowdryrider
slowdryrider
574
784
Canada
On my Honda 700 I used a GM Chev light truck one. It's Vacuum operated but I ended up removing the vacuum part and connected a push pull cable to it. Part # GM 15714784 [660-1357] or Four seasons # 74607 .
I didn't set my 1000 with this due to my heater being under the seat.
Hawk53
Hawk53
485
622
Alberta Canada
Thank you. It appears to be currently unavailable
on amazon also.But thats the idea.
JMynes
JMynes
546
3,241
Augusta, Maine
With two ball valves and the appropriate barb fittings you can isolate the heater core. If you’re worried about old coolant, just flush it once in a while.
With a third valve you could cut off the radiator to maximize cab heat on those frigid ice fishing excursions.
Reactions: Lady01
Hawk53
Hawk53
485
622
Alberta Canada
Thank you,I wouldnt have any concern at all with the coolant sitting in the heater core. The only time I would want to isolate is when I have a heavy load on and pulling my tub trailer through a hilly, sandy area where I cannot get much roadspeed.
Reactions: Lady01
Hawk53
Hawk53
485
622
Alberta Canada
What size is the heater core lines?
5/8" is the heater core lines. There are barbs and adapters that hook the heater core in series from the engine oil cooler to the water pump which is a 1/2" line. I am looking for something neat and tidy like the valve that I posted.
Reactions: Lady01
