P1000 Vent relocation kit
5,048
22,627
Since Mr. @Bayouownbeer seems to be busy, check out his info here -
Bayouownbeer
Bayouownbeer
786
1,061
Chauvin LA
A member here sells a great kit with great instructions goes by buyyourownebeer, well that's what his handle implies, some one will chime in and give you contact info.
I can save you about $8 if you PM
https://www.ebay.com/itm/3136646210...ep_vectorid=229466&kwid=902099&mtid=824&kw=lg
With filters recommended for 3 seater pioneers and the Talon unless you drill three 1/4” holes to put the ends of the tubing into. If you don’t heavy mud you can use the kit without filters and simply turn the ends down 90 degrees.
“The Original” Honda Pioneer 1000/700/500 & Talon Vent Ext. Kit. With filters | eBay
Bayouownbeer
Bayouownbeer
786
1,061
Chauvin LA
Thanks
