P700 Vibration when in 4x4 right before shift
mchaulerz
Bradenton, FL
Any of you experience this? I notice it most when in 2nd gear, before it shifts, it vibrates quite a bit. If I let off the throttle to keep it in 2nd, it vibrates the entire time in the upper range of rpm's.
I can have it in 2 wheel drive and never experience this.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
4wd drive will do that kind of stuff sometimes. I don't THINK you have anything to worry about. Seems someone reported this before and the cause was his front tires were inflated to different pressures! I couldn't hardly believe it but he said once he got both tires at the exact same psi the vibration quit. At least it's something easy you could try, not sure how bad the vibration is.
