Multi Viper Elite (Wireless)
KyleC
KyleC
102
155
Pittsburgh, PA
Anyone else install the Motoalliance Viper Elite winch on there machine? Instruction say to power the wireless receiver to a “key-on” source, however, this means that you have to program the remote, to the receiver, every time you turn your quad off... Am I missing something? Should I power it to a constant source instead? What would the draw be...?
68,409
It shouldn't "unprogram" let me check into this.
Reactions: KyleC
KyleC
KyleC
102
155
Pittsburgh, PA
Thanks Rich! I also contacted MotoAlliance, was just curious if others experienced this (normal), or if I wired something incorrectly. Works perfect while running, after programming. The rocker switch fit perfectly into the plate purchased from Mystic too!
68,409
Are you talking about activating it each time?
I really cant find anything on programing. In fact it says each remote is programmed to the unit to prevent interference from other remotes.
Activating is a safety thing and must be done before each use so you dont which accidentally.
KyleC
KyleC
102
155
Pittsburgh, PA
Probably. I was assuming that when I have to push the button on the receiver, that it was syncing... Did not think about considering it as activating and a safety thing.
68,409
Pushing both buttons for 5 seconds is a safety thing.
Reactions: KyleC
KyleC
KyleC
102
155
Pittsburgh, PA
You mention both buttons, can I just hold down a button for 5 seconds on the remote in lieu of the receiver? I’m away from the machine currently to test.
68,409
Not sure.
The info I have says both.
I have a wireless system for mine. But I havent installed it yet. Too many other projects.
Reactions: KyleC
KyleC
KyleC
102
155
Pittsburgh, PA
Not sure.
It was bugging me... ran out there. You do NOT have to use the receiver. If you hold down both buttons on the remote, for 5 seconds, it will activate. Works like a charm!! Thanks Rich!
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Damn I took mine off because I thought I had to push the activate button each time I wanted to use it. I guess I'll reinstall it!
