Dragon21
Who has one. 2nd one in a row that looks like this. Does it straighten out when mounted, or is defective
I dont have a warn but...that cant be right. Im pretty familiar with winches and have never seen one warped like that.Who has one. 2nd one in a row that looks like this. Does it straighten out when mounted, or is defective
View attachment 56032 View attachment 56033
Different sellerDid they send you back your first broken one?
Sent from my XT1565 using Tapatalk
I have taken mine apart many times and there is a hex shaped rod #8 that transfers motor movements to the gears on the opposite side! Now pay attention to #5 which sits on the end of the hex shaped rod. It should fit into #4 which sits on the motor side! My guess is if you remove or loosen screws #19 from the two rods #10 which hold the two half’s of the winch together you will be able to verify they are fitting together correctly. If they are mount the bottom of the winch to mounting plate using bolts #21 and after all 4 have been started then you can tighten the top.Who has one. 2nd one in a row that looks like this. Does it straighten out when mounted, or is defective
Thought about tightening it down and see if it does. Then put a helicoil in it or go bigger. Or just leave it like it isMine same front bolt hole striped as well. I tapped it one size bigger and put new bolt in.
Not a nut on theirs, it’s threaded into the housingwhy not order a new nut from warn and replace the messed up one?
This is my first one. Company tried blaming me. I didn’t even notice until they sent me the picture and tried to deny my refund.
That ProVantage is sexy looking and so shiny, and that cable...
