P1000 Washing the dash with a pressure washer
Trailtoy
Trailtoy
26
64
Canada
My dash is all kinds of dirty, dusty, grimy. Don’t guys go at the dash and floor etc with a hose or power washer? Is it safe to blast the thing to death? Or is it windex and soft towel only?
IMG 1632
68,280
Factory it would be fine. Leave the key in it to block that hole. Just wash/spray it... Dont blast it "to death".
Secondary accessories and modifications is where your issues will be. EX. that radio.
Trailtoy
Trailtoy
26
64
Canada
Yes, that radio will have to be protected somehow. So every thing else is water resistant then. Perfect!
Reactions: ChadD and TxDoc
john790
399
1,154
Clinton ohio 44216
My answer would be never.Every floater ive been around car or truck has been bad news.
Reactions: ChadD
RacinJasonWV
RacinJasonWV
95
249
WV
You mentioned Windex. I don’t think they recommend using that on the windshield.
I pressure wash the dash gently, making a point to stay back and keep moving.
bumperm
bumperm
1,929
6,828
Gardnerville, NV
No way I'd try that. A pressure washer has (duh!) lots of pressure, and that pressure can force fluid through otherwise tight seals etc.
If it's that dirty, I'd mix a weak soap solution using Dawn dish soap or similar. Rinse with low pressure clear water first to get rid of grit that can scratch stuff, then apply soap solution with a soft brush or microfiber cloth. Finish by rinsing with clear water and then dry with microfiber cloth or one that is damp and wrung out, as that tends to absorb water better than a completely dry one.
Reactions: ChadD
P1K5Dave
P1K5Dave
2,330
8,691
Petoskey, MI
I hit mine with the pressure washer, but not a direct blast. More of a light glancing spray from the side. A quick wipe-down with a rag to follow up.
Reactions: RacinJasonWV
futzin
futzin
4,786
35,098
Kentucky
Been spraying my P5 (and a Foreman) dashes for years, no issues. Keep the wand moving, don't get too close. Being aware of aftermarket add-ons is great advice. Honda sells them with no roof and no warning not to drive them in the rain. Just sayin' . . .
A while back I went to fill a tub with water with the pressure washer. It made me realize how little water they actually put out.
