Watch out for those trees!
4be5ae238181c721dfd0c2e8535bcce8
I'm very surprised that a small brush against a tree caused this. It wasn't even a very hard hit. I just brushed a tree and kept going.
After seeing the mounting tabs, I think this is a safety feature to keep from breaking something serious. The upper A arm mounts are positioned under the frame so they are actually very weak when hitting something head on. The lower A arm mounts are position on the frame and very strong.
3e7951ab3d72e719a25563bbcac3f7cd
266,483
@joeymt33 OUCH! did it tweak your upper A-arm? That's what it looks like from the cant of the tire. :confused:
Time for some HD A-arms from Super ATV :cool: Always look at the bright side of any situation :D
You can see from the pic that the upper rear A arm mount has no support behind it at all. I tied the back of the pioneer to a tree and ran the winch through a snatch block back to the Upper A arm out at the knuckle and pulled it straight with ease. I thought about adding more support but if it happens again it may break something else. It was actually a quick and easy fix. What do you guys think?
E71679bca21ee314176b9692df88245c
Actually, the A arms did not get tweaked at all. I'm telling you, it was so easy to bend back that it must be designed that way. If it was stronger, I may have bent an A arm or tie rod and been in worse situation.
Joe.
266,483
It "looks" ok from that last picture, only time on pavement will tell you if it pulls one way or the other, Might measure front to rear axle on each side and verify it is the same wheel base. Then again maybe you don't want to know :confused:
Reactions: bobbyhill
When I installed a new lift, I will scrape the paint off and check for cracks and re-weld since it's now been weakened.
I think I pulled the A arm a little too much because now the tire camber is out a little. I'll fix that too, soon.
Joe.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
WOW! That looks bad! I am glad hear it was easy fit and it didn't wreak your wallet. Great post!
