So I just added two lights to my already set up and running 4 gang rocker panel. In the 4 hour fight of me trying to fit my arm in the gap, I somehow detached my winch trigger wire for the switch. I have it now wired together with my key on harness in the relay that controls all my key on 2nd battery accessories.
Mind you the winch was working fine like 3 days ago. So now I turn it over fine, and my rocker panel takes like 45 seconds to get lit up, and on top of that my winch is doing some weird stuff. So I’ll hit the dash button to let out the winch, the solenoid will click, the winch will move maybe an inch, and stop, and my toggle switch panel that’s not even wired with the winch (I have a separate switch for the winch) completely turns off. It’ll stay off for like 15 seconds then like click on.
My batteries reading 14.2 when it’s running so I don’t think it’s a battery issue. I’m just scratching my head on this one. Like it’s almost like the winch is pulling the power from everything rather than just the battery. The winch is wired directly to my 2nd battery. Solenoid is getting all 12v.
So I’m wondering if me hitting the switch is screwing with that key on relay and basically closing/ opening the gate for the power.
