ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
Started looking at my rear winch mounting location. I couldn't visualize a bolt in solution today but I can visualize a more permanent welded on mount above the hitch.
PXL 20211227 000641555
PXL 20211227 000652578
PXL 20211227 000649154
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
I think you and @ CummingsPusher are the first.
I was thinking about a winch plate mount that plugged into the receiver, for portability.
Great idea
I hate the slop of receiver mounts and there's no way I could give up that departure angle. I had a tiger tail strap and it would drag on everything.
05Willys
05Willys
529
3,323
Take it out and put it in the bed until needed? They make battery cable connectors that I'm sure would work for the power.
05Willys
05Willys
529
3,323
Don't see one, but using a battery hold down is a good fire safety idea I think. One easy way to do so is to use a cinch strap (nylon strap with cam type lock). I cut mine to length and attached to compartment side walls with hot melt glue. That was after testing strap adhesion on scrap piece of plastic to make sure shear strength would be adequate.
I cut the strap off of a Coors Light cooler bag and sheet metal screwed it to the plastic.
20210718 192520
bumperm
bumperm
1,931
6,829
Gardnerville, NV
Looks good.
I was originally going to use these: Bimini pad eye using rivet nuts and screws, as I was concerned wood or sheet metal screws directly in the plastic might pull out - but then I got lazy and reverted to the glue - sigh.
Reactions: 05Willys
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
I would have never winch backwards from here but this was one of the few time I got stuck this year. I'd say most times, I'd never get the winch in the receiver if it wasn't there before I got stuck.
In this particular spot we winched forward 2 full cable lengths and tied off at least 5 or 6 times with a snatch block. The ruts were deep
PXL 20210615 160451655
Scoop
Scoop
5,441
21,390
  3. Talon R LV
I cut two small slits slightly larger than the strap itself in the bottom of the AUX battery box. I fed a 2' long piece of double side 1" Velcro through one, around the underside of the box and back into the box. I dropped the battery in and then cinched the Velcro strap tight around the battery. This way, I don't have to worry about glue adhesion or rivets/screws pulling out.
Screenshot 20211227 085726 Dropbox
Seth14
Seth14
66
408
Indiana
It’s in the works. Didn’t get to that point yet. Thank you for looking out though! It needs done.
Red21
150
487
sioux falls, sd
I ordered a windshield from SuperSuv. Ordered today (Monday), and its supposed to be here Wednesday. Thats quick service
StewB
StewB
770
3,566
Finally having a snow-day here to try out my plow setup. Not much snow but since I've never plowed before it was just enough to figure things out. Now it's time to play with the other toys!! I smell 2-stroke!
Saw your set up and thought I'd pass on a prior link. One of the reasons I use a dolly is to drop the blade onto wood and not have the skid pucks chip the cement garage floor. Just an idea.
wolf359
wolf359
64
403
Appalachia
Thanks for the thought but if you could see the damage a carbide tipped snowmobile stud does to concrete you'd see there's not much hope left for my garage floor. It keeps the weather off the toys and the mud off my feet so all is well. If I ever have a new garage a lot more care will be taken.
Vikes79
Vikes79
SKOL!
12,065
115,896
South Dakota
  2. Talon X4 LV
Added a simple suicide knob to my P1k5 today.
10 bucks at local farm ranch store.
Now I can steer and run my winch easier with my left hand, while shifting / turning blade with my right.
bolts in the pkg are just long enough to engage the nuts when fully tightened down.
CFCAD3BB 9DD5 4D49 B3B1 26B95E120375905AA1FE 2111 48AB 99AE BBC9C210D63B
