G
Gassygordo
302
1,025
Fillmore, NY
0E08A7CC DFEC 430D 9970 7368C699263C
81A0306F EFAC 4728 A4B9 ED2535087395
F5F8D83B 5D53 48D4 8ADA 703DCD18C5B8
Winched up another ladder stand. My P5 with wireless remote control winch makes it a one man job.
11,319
84,114
After being unaware of a bad voltage regulator that fried a battery, installed a voltmeter with USB ports. It was accurate with my hand held voltage meter.
F435C5E6 5C37 426A 85F4 98926DC1B0C7
11,319
84,114
Congrats @ToddH , which color? A low setting heat gun (or hair dryer) is mentioned in the instructions. Be careful, a little heat goes a long way. Did mine without removing the frame body around light, just pulled it out slightly and used small screwdriver to press the rounded edges in. Have some rubbing alcohol on hand to clean the glass.
Todd627
Todd627
56,297
615,153
MI
Congrats @ToddH , which color? A low setting heat gun or hair drying is mentioned in the instructions. Be careful, a little heat goes a long way. Did mine without removing the frame body around light, just pulled it out slightly and used small screwdriver to press the rounded edges in. Have some rubbing alcohol on hand to clean the glass.
Thanks for the advice @Mudder. I ordered the same green eyes you did. :D
Backwoods
Backwoods
32,298
331,560
Douglasville ga
That's what I did alcohol , hair dryer , screw driver . Took about 5 minutes super easy mod and they disappear at night with your headlights on.
Russ989
Russ989
22,571
146,542
I got a pair of front Elka stage 3 shocks the other day and put them on for a run yesterday. Did a 100 mile run and did not bottom out once. In my opinion this has made my machine more of a pleasure to ride on. Just not having to shift down and up, drive around or brake for every bump makes it that much easier on my machine. I can't wait to get the rear ones. That will have to wait. I don't understand why Honda doesn't offer something like this on there new P5's. I think it would put the machine in a whole new category.
Yeah, the stock suspension on the P5 is pretty rigid. Mine was rough and if I would have kept it I would have definitely upgraded the shocks.
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
Installed the Dusty Dawgs rack and took the P5 into the Tobacco Roots Mountains scouting for elk.
The upper rack coincidentally is the exact size and shape as my 2-compound bow padded case. It’s light weight to be up high, protected and hopefully will not get covered in kicked-up road dirt like when it was strapped behind the seats last year.
264088feaad0f9ea59a2915d3250a55d
E7954cb939823d32b5da89eebdbc0f1f
Russ989
Russ989
22,571
146,542
That’s pretty nice! Was it expensive or fairly reasonable?
Reactions: rtn001
rtn001
rtn001
317
945
Central Florida
Took the camo wrap off and painted the P500 with Flex-seal black, What do you think ?
View attachment 148217 View attachment 148218 View attachment 148219 View attachment 148220 View attachment 148221
That is a good looking sxs. A friend of mine had his sxs sprayed with a line x type/ looking black and I loved it. I like yours much better. He says his a pain to clean due to the textured finish. You would think he would have known as he had his Dodge pickup sprayed with the same thing a few years back. It looks great.
