P700 What do you think
Backwoods
Backwoods
35,807
362,226
Douglasville ga
Finally home from hurricane work in Florida. I want to buy bigger tires I already have my favorites narrowed down but I am torn between 26s and 27s. Is the extra weight worth the extra 1/2 inch of clearance and I like the look of my deluxe wheels. I also like the extra off set of after market what do y'all think? I don't much care for spacers but will use them on rear If I stay with deluxe wheels. I also don't want to bog it down bad either.
Reactions: CumminsPusher
allgm1
allgm1
1,049
1,484
New Hampshire
I guess its really up to you. I put 26" on mine, and also went 1" wider. I can't really say I noticed any loss in power. I'm sure someone else has run 27's maybe they will chime in.
Reactions: Backwoods
allgm1
allgm1
1,049
1,484
New Hampshire
Backwoods
Backwoods
35,807
362,226
Douglasville ga
Thanks I figured 26s I wouldn't notice anything but 27s would probably make a difference. I like riding in the mountains and didn't want to take away from it with to much tire since power wise it's fine now.
BrentW
26
14
Arkansas
My 28's have a little low end power loss but evens out at normal speeds.
Reactions: Tflynn
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I run 26” tires but if I had it to do over I would probably go with 27” tires. I was worried 27” would change performance too much but from reading guys posts on here I don’t think it would have. But I’m still happy with my 26” RipSaw’s.
Backwoods
Backwoods
35,807
362,226
Douglasville ga
Thanks for the info I will probably go with 27s since they seem to be the preferred size I was mostly worried about low end grunt on steep sections.
K
kukini
40
90
Maine
I currently run the 27" Sedona Coyotes(6-ply) and I have been very happy with them after 1600 miles of mixed terrain use. They've worn well and I've noticed very little power loss. Although I have taken a fuel mileage hit from the extra weight.
Tire1
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I moved up to 26” when I got new tires. Wished I went with 27’s almost immediately. Could not feel ANY loss of power with the 26’s. Hard to imagine 27’s would be that different. Plus bigger tires smooth out the ride more than you’d think
Backwoods
Backwoods
35,807
362,226
Douglasville ga
Ordered tires today will pick up tomorrow. I went with 27s. I think they will look fine on my deluxe wheels if not I will orde r new wheels. Will post pics of them. I will put one inch spacers on rear to even it out.
Backwoods
Backwoods
35,807
362,226
Douglasville ga
I started to I used to on my ATVs but I went 9 in front and 10 in back I didn't know if 10s would rib at full lock or not.
Backwoods
Backwoods
35,807
362,226
Douglasville ga
Tire guy called only 3 tires showed up. Kinda ticked me off but it wasn't his fault but I will have them all by first of the week.l made arrangements for some one to take it and get them mounted while I am at work and bring it back to house for me . I will take pics when I get home.
Reactions: Mudwing
Backwoods
Backwoods
35,807
362,226
Douglasville ga
Ordered 212s they will be here Friday will post pics that evening.
Backwoods
Backwoods
35,807
362,226
Douglasville ga
I hope I like the way they ride .l may not put them on tonight I am tired and I have to work tomorrow.
allgm1
allgm1
1,049
1,484
New Hampshire
I hope you put them on and go get some dirt on that poor thing. Then take some pics please.
