P1000 what is best second battery... odessy maybe?
sheba4
161
197
mn.
  3. Big Red
ok I am about to order a second battery for when I get my accessories installed... I like the way appalachien
mountain riders installed his.. the odyssey extreme pc925, do I need this good of a battery? 189.00 plus I will get the battery install kit for 89.99... what are you fellow using? next I will be asking you about switch plates and so forth... I am pretty mechanically inclined but not with wiring... I may just have Honda do this but I think I can get through this...
thanks,
Gary
Reactions: Plumber32 and sharp
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
thanks,
Gary
There's several threads regarding battery/installs if you dig around the site... should be easy enough for ya if you just copy someone else's install.
I'm using the odyssey as a lot are, but there are other options... this thread has a list of compatible batteries. The mighty maxx is another popular choice due to price, however I recall at least a couple of posts regarding problems with them.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Several threads going on this topic already. @Hondasxs can help you out
Reactions: Landman and sharp
BigOL3
BigOL3
2,994
8,920
By no means am I even close to any type of 'expert' when it comes to electrical wiring ...... BUT, I can assure you he is NOT correct when saying ...... "you MUST run a battery isolator with dual batteries". That might be the best way to cover all bases but it is NOT required in order to run 2 batteries. I do not have an isolator, but I do run 2 batteries.
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Wiring in a Stinger to a switch to “kill” all secondary power is a good idea too. Installing the secondary battery can be as complicated or easy as you make it. LOTS of threads on this subject. I’ll also be posting a detailed video on my setup in my build thread, SuperBee,(when it’s complete), I just need to mount my isolator, Stinger, relays and fusebox.
Reactions: sharp
69,249
thanks,
Gary
I've got the same setup as the video you posted. Works fine.
Here’s mine..
29755D37 A067 4638 B240 F68D66416CA4
07F5BFEE 0D59 478C 9C90 476D8869BDF1
sheba4
161
197
mn.
  3. Big Red
ok thanks, do I need a stinger and what does it do?
I see you moved a few things around..
how did you attach your battery strap?
I think there are 2 models of that battery? pc952 and pc925 and a letter I believe?
thanks,
Gary
thanks,
Gary
I did mine long before this video... as @Hondasxs said... the stinger is there for turning on and off the accessories. Think of it as a master switch. It allows me to run my accessories with the key off. The battery diffence is right or left negative post as I recall. My battery strap is a cam strap I ran under the plastic indention for the battery. I then cut a slot in the plastic on the radiator side of the steel cross member that is under all the plastic. If you look at the battery spot there is about a 2” flat on the radiator side of the that spot. That’s where the cross brace is.
Chriscoe
Chriscoe
83
131
Seagrove, NC
I’ve had the mighty max battery for a total of 8 days. No problems so far
Neohio
Neohio
Beast of the East
17,836
86,047
Painesville Ohio
I had issues with my mighty max after roughly a year. It dropped a cell and would only hold a 10v charge. I don't recall anyone else having problems with theirs. I hope yours works out for you.
Reactions: Landman
mississippimud
mississippimud
31
159
north mississippi
Hey guys,been a while since I posted but
I have had trouble with the odessey battery dropping voltage quickly and not holding a good charge. Been running accessories on it for about a year. Could have a weak cell??
If had to do it again i would go with the cheaper battery!!
sheba4
161
197
mn.
  3. Big Red
ok thanks, I guess I will give the mighty max a try...
Gary
