P1000 What is EPS?
105,297
STEERING POWER ELECTRIC
7374EC6C A0E5 4246 BF92 FCF488706CAC
bumperm
bumperm
1,848
6,641
Gardnerville, NV
Welp, mind you I've never tried this, but it should work. First you tie some strong cordage (Dyneema or Spectra should work) to the distal end of "IT". Secure the other end of the cord to a sturdy object such as a tree. Helpful hint, leave enough slack so you can climb into the driver's seat, plus at least 10 feet of loose slack. Get your motor running and give 'er the gas in high if your brave, or in low if not so much. As soon as you start moving, scream at the top of your lungs - this will save you one less thing to do in a few moments, and will add to whatever entertainment value that comes of this. Please have someone get this all on video so, when you're able, you can post back here.
No need to thank me, you're welcome.
Test - Grid
