P1000 What size tires for your Honda Pioneer 1000?
What size tires will you run on the P1k?
  • 26 inch or smaller
    Votes: 1 0.3%
  • 27 inch (OEM Size)
    Votes: 58 16.7%
  • 28 inch
    Votes: 156 44.8%
  • 29 inch
    Votes: 35 10.1%
  • 30 inch
    Votes: 88 25.3%
  • 31 inch
    Votes: 7 2.0%
  • 32+ inch
    Votes: 3 0.9%
  • Total voters
    348
P
Pioneer1k
9
19
ORB will be making high clearance forward a a arms for the front to clear 30s
Reactions: Hondasxs
P
Pioneer1k
9
19
Yes he is a friend of mine we will be making some next week for my 1000
Reactions: TOOLOUD
Kenjones21
Kenjones21
165
107
Central Louisiana
26 inch big horn mounted on 12 inch wheel with 8 psi next to the 27 stock big horn 2 on factory wheels with 14 psi , the 26 is definitely taller , didn't pull out tape measure but they for sure ain't a true 27 inch tire .
68,286
WHAT...
I know there 4 ply vs the normal 6 but... Omg.
K
Kyle
Isn't that the same picture as the 30in bighorn next to the stock 27in someone posted earlier?
K
Kyle
Is the offset for the front rear factory 14in rims the same so we can buy the same width tire for all four corners? I just want to be able to rotate them if I buy 10s all the way around.
Offset and width are not the same front to rear. You can still run the same size all around though.
K
Kyle
Ok thank you! and I was just going to run same size all the way around only if I could rotate them. I learned the hard way on my old wheeler trying to rotate tires that were the same width but the front and rear rims were different width and offset.
Might go with either 28in itp blackwater evos or 29in original bighorns if the bighorns will clear, so someone figure out if 29in original bighorns will fit with no lift :)
F
Fullthrottle
164
84
Same size all the way around didnt say the wheels could be ran front to back.
K
Kyle
I know they can be but if the rear rims are wider and fronts are skinnier which I'm assuming they are why would you want to switch them around. It would look goofy and probably rub up front. That's why if both front and rear rims are same width and offset like the aftermarket ones we buy you can just rotate the tires and rims with no issues.
F
Fullthrottle
164
84
My bad yes I agree.
TOOLOUD
TOOLOUD
261
155
Benton,La
Looks like I'm gonna run my 28" radial outlaws that I already have on mine until someone comes out with some forward A-Arms.
