P1000 What size tires for your Honda Pioneer 1000?
What size tires will you run on the P1k?
  • 26 inch or smaller
    Votes: 1 0.3%
  • 27 inch (OEM Size)
    Votes: 58 16.7%
  • 28 inch
    Votes: 156 44.8%
  • 29 inch
    Votes: 35 10.1%
  • 30 inch
    Votes: 88 25.3%
  • 31 inch
    Votes: 7 2.0%
  • 32+ inch
    Votes: 3 0.9%
  • Total voters
    348
tig
tig
116
176
26 inch big horn mounted on 12 inch wheel with 8 psi next to the 27 stock big horn 2 on factory wheels with 14 psi , the 26 is definitely taller , didn't pull out tape measure but they for sure ain't a true 27 inch tire .
I bet if you measure it sideways instead of vertical it'd be 27. The weight of the machine will compress the tire 0.5~1"
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Nobody going bigger on tires yet... 29in bighorns ... 28in blackwaters something...pics and info anyone or is everyone waiting on a-arms
I'm waiting to see what will fit I went through a couple of sets of tires last time because I didn't do my due diligence and figure out what the true sizes of each tire was I was considering and what the true size was of tires people had mounted and how much room they had with various lift kits.
No lift kits are ready YET for the 1000 but I will probably only add @2" the 1000 sits fairly high stock. If the factory tires measure 25-26" I'll only put 28's but if they are true 27's I might see if 30's will fit and forgo a lift.
I just want a bit more clearance, the clearance of the 1000 is close to what my 700 was with lift and tires and a whole lot of added weight in accessories. I'm adding not as much weight in accessories so I know I'll need to regain a bit of clearance to ride most of the places I rode my 700
F
Fullthrottle
164
84
Surley somebody has has tried some bigger tires again? Anybody?
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
I'm gonna go with 29" bighorns more than likely. I want 30" Roctanes but I doubt they will fit without a lift.
Reactions: Hondasxs
AKTMW
AKTMW
82
115
Anchorage
Fd6a35d6d347d12166cbd2fb4f3c4f87
28 inch blackwaters...
No rub when turned hard over? The stock 9" wide 27s looked close. I'm thinking 28", 11 wide rear, 10 wide fronts. Wish they made a 12 wide blackwater evolution.
Actually I wish we could clear 30s w/o a lift, but that may be asking a bit much.
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
Can you get a side shot without it on the woodpile?
I don't have any other pictures on my phone. When I get home from work tonight, I will see what I have on my computer. If not, I will just take a few tomorrow.
educ8tedguess
educ8tedguess
403
972
  1. Looking to buy
I don't have any rub at full lock. I took it to a terrain park this past weekend and put it through it's paces. Rocks, ruts, roots, climbs, etc... and no rubbing. And... these tires did AWESOME in all conditions; even in some mud. Quite a bit better than the BH' 2's I had on my Yamaha Viking.
Those Blackwaters look great! Congrats.
