P1000 What size tires for your Honda Pioneer 1000?
What size tires will you run on the P1k?
  • 26 inch or smaller
    Votes: 1 0.3%
  • 27 inch (OEM Size)
    Votes: 58 16.7%
  • 28 inch
    Votes: 156 44.8%
  • 29 inch
    Votes: 35 10.1%
  • 30 inch
    Votes: 88 25.3%
  • 31 inch
    Votes: 7 2.0%
  • 32+ inch
    Votes: 3 0.9%
  • Total voters
    348
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
You find the 28x9 blackwaters to be about same width as 27x9 OEM bighorns on the OEM wheels. Pretty much staying under the fenders?
Honestly, I never saw my machine with the stock tires. I had my tires put on before I picked it up. But the tires I have don't stick out much, if at all. I went through some pretty sloppy stuff and I stayed cleaner than I have on any other machine I've owned
Reactions: Bayouownbeer
I've got some info on tire size for those that would like to go bigger. Check these pics from a fairly small jump. My P1000 has stock suspension and stock tires/wheels.
Not much room for a bigger size of you plan on ridding like this.
Front compression
79ce8c943af30a5c13828f30ee947a0a
Rear compression
Ce10c5be8c6aaa0ff5e53b6feb80b094
Video of the small jump
Yeldarb
Yeldarb
34
65
Gilbert, AZ
Went with the STI Chicane in 28x14x10 on all 4 corners. Gained a full 2 inches of ride height compared to the Bighorn 2's, a combination of the bighorns being less than the advertised 27" and the Chicanes being a bit larger. Did require a slight modification to the Trail Armour skid plates where it was rubbing in the front at full crank. No rubbing issues stock at all.Image
283,395
Went with STI Roctane XD 30x10x14 all the way around, they are actually 30.4" tall also running Strong Made 2" lift kit. Combined went from 12" ground clearance to 16". Clears factory plastic fine.
Side Profile LT
F
Fullthrottle
164
84
Where's all the pics of bigger tires on stock wheels.
Bonehead69
Bonehead69
73
44
any of you guys who bought new tires and rims looking at selling the stock ones? I'm looking for the deluxe rims/tires or even just the rims.
amc019
amc019
480
592
Little Rock, Ar
I'll have the stock tires for sale this weekend, but not the rims.
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Did you add your hometown in profile update... That's cool didn't know how close Bonehead69 is but I could sell rims and tires if I could afford what I want
amc019
amc019
480
592
Little Rock, Ar
Yes, there is an option for that. It helps to know where everyone on the forum is coming from imo.
In other news, I pick up my 1000-5 tomorrow and plan to run 30x10x14 STI Outback Max's on the stock wheels with a Strong-made 2" kit. Hoping they fit without too much trouble. I don't mind a little rubbing on some plastic. Getting the 30's mounted at the dealership before I install the lift at my shop so hopefully I can at least get it on and off the trailer on the stock suspension, just maybe not turn to much.
Reactions: pct
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Jackal has the strongmade and I plan to get it also but he got aftermarket rims with a tight offset and had to heat some plastic
Reactions: pct
