P500 Wheel spacer question
DaveinWV
38
141
WV
Are offset rims easier on wheel bearings than spacers? I'm thinking of 1" spacers or rims with a +3 offset for the rear. I realize spacers would be less expensive.
Reactions: pappyo
Fatsquatch
Fatsquatch
Approved Member
121,609
1,013,749
Hidden
Likely less overall rotational mass so probably a little better but the actual leverage factor (all things being equal in overall width) is the same.
My uneducated opinion but I’m curious to see what peeps smarter than I have to say.
For sure making sure lugnuts and spacer nuts are tight helps prevent issues on the trail. Nomojic
Mopower58
Mopower58
Unburdened by what has been!
88,331
755,889
Crystal Springs,Ms.
I would think the difference in offset wheels vs a spacer would be negligible as far as bearing load. If you use spacers I would recommend @RB3offroad and use loc-tIte on the spacer retaining nuts and a torque wrench.
JayPo
JayPo
Somewhat Well-Known Member
16,614
151,476
Tennessee
Pfffft. All this talk about checking lugnuts, using loctite, and quality spacers is overrated 🤣
20240127 143443
Actually I did check lugnuts and used loctite. I think the problem was crappy spacers. 🤦‍♂️ I've now upgraded to @RB3offroad spacers 👍
KyGal83
KyGal83
9,623
93,669
Kentucky
It was this exact moment... Wobbles was born.
P
pappyo
613
2,454
How to Keep your Nuts --Exposed & Tight -- using Spacers.
4on110 to 4on137 -- 1inch Spacers -- ( Can Am Beadlock wheels )
Can Am guys always doing upgrades pickup these for $200/300 set of 4 on facebook -- Craigslist .
Pictures are on 2022--P520 -- ITP 27X12's XTP Tires
54/54-1/2 Wide
20240607 203230 20240607 203234
