P1000m5 Wheel Spacers and Lift
Cattrell
Cattrell
49
81
Church Hill TN
I am thinking about adding a set of wheel spacers and a small lift to my rig. I am looking for a little more clearance and a wider stance for stability.
I do not want to get into a huge modification.
Any suggestions on the best way to do this and what kit to use?
Thanks!!
Jeff Cattrell
RB3offroad
RB3offroad
1,712
4,815
Tempe, AZ
Thanks!!
Jeff Cattrell
Jeff, We have different sizes of wheel spacers. Our most popular is the 1" front and 1 1/2 on back. Adds stability and stance. We also have the extra wide track bundle. all of our wheel spacers come with hardware and are anodized to protect your spacers. We have a discount for members. orders over 120 use code taketen for $10off. You can call me if you have any questions 480-389-7486
Reactions: Bones and Cattrell
Cattrell
Cattrell
49
81
Church Hill TN
There are several threads on this.. some even recent. @RB3offroad
I have seen several on the spacers but can’t find anything on a small lift. I am looking for someone who has done the two together for some advice
Superthrill
667
1,557
North Carolina
I did the wide track spacers and the spring spacer lift .
Love the width, and the added preload from the spacers, I really like it now. I no longer feel the need to upgrade shocks as bad as before. I do carry a load of tools, spare, gas and cooler.
I got the ride height back with the extra preload. I do not want it any higher.
Also, loose the sway bar...
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
I gotta agree 100%. The only difference is I haven't lost the sway bar........yet. I was afraid that the ride with the small spacer lift would be worse, but I swear it seems better. I will eventually do Fox or 814s but that will have to wait on $$$.
Cattrell
Cattrell
49
81
Church Hill TN
So who has the spacer lift? That sounds like an easy add to try
Thanks!
I am looking for a few more inches of clearance
What size tire are you currently running or going to run? 2.5” Highlifter is what most of us are or were running. If you’re going to a 30 you’ll need forward a arms and you can get your clearance that way.
Reactions: RB3offroad
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
Reactions: Cattrell
Cattrell
Cattrell
49
81
Church Hill TN
What size tire are you currently running or going to run? 2.5” Highlighter is what most of us are or were running. If you’re going to a 30 you’ll need forward a arms and you can get your clearance that way.
I am running stock tires,
I am running stock tires, I think the highlifter is exactly what I was looking for, I will try that with the wheel spacers !
Thanks for the help!
Superthrill
667
1,557
North Carolina
Spring spacers give you more preload and act like a higher spring rate. Which in turn raised the ride height back up.
I was bottoming out real easy. A lift will not help that if you have those issues. Otherwise the hi lifter will get you clearance.
Reactions: JTW and Cattrell
