Which jack is best?
Which jack is better?
  • Scissor jack
  • Hi-lift jack
Results are only viewable after voting.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
With the recent addition of a spare tire, I must now decide on which jack to carry. I could get a Hi-Lift mount (already have that jack) for $50 or I could get a Tusk scissor jack and mount for slightly more. Each option has pros and cons. What do you guys think?
d_b
d_b
302
240
The one you don't have to use...
Reactions: Tflynn
39,079
The best Jack is "silver select". Oh wait, you meant a mechanical device....
Reactions: Gator and Tflynn
63,402
the scissor jack has its weight advantage but the Hi-Lift is more useful.
Difficult decision. I own a hi-lift but don't plan to carry it on the trail.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Yeah the hi-lift is way more versatile for sure. My only problem with it is weight and then I'd always have to carry WD-40 with me too because the damn things don't work without it! But that might not be a bad thing to have handy.
So what exactly is the difference between a regular hi lift and the utv hi lift anyway?
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
I would go with a hi-lift all the way. I didn't know they had a shorter UTV one. Try putting some water on your pins, that has worked for me in my jeep to get them to work before when they wanted to be sticky. And usually you have a bottle of water with you. Hell one time we even used Budlight but its pretty close to water anyways.
At least with a hi-lift you have a backup winch and they work good as a clamp or to straighten bent things too.
Reactions: Tflynn
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
I may have to get that one. The one I have is 42" tall I think? It's huge and heavy.
If its the normal Jeep one I think they are 48" If you know you're not going to use it for anything else you can take a hack saw to that one and shorten it to whatever size you want. The slider pin kits are super cheap too. like 17 bucks Jack Repair Kit
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Thanks for the link.
dale5740
dale5740
886
416
mt airy md
neither
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
No problem. I used to keep a kit with me in the jeep for some reason. At least they are dirt cheap. I think some auto parts stores even have them every no and then.
I would also highly recommend getting the hi-lift or daystar jack isolater bushing. It keeps everything from rattling and also helps keep the handle from getting lost. Jack Handle Isolator
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I wonder if anyones every tried one of these for a UTV Bushranger Inflatable X-Jack
Yeah I don't know about those. Everything I read says they work great I just think in the off-road world, those aren't going to last too long. I like to buy stuff that can last forever or at least close. I guess most of us do that's why we're on the Honda forum!
sharp
sharp
3,757
14,955
Tennessee
Hopefully you won't need one but either one will get you back to camp
Reactions: Tflynn
tjoreo
tjoreo
1,010
1,929
Southern Idaho
I think if you look through Jackal's Baby Honda build (500) he has one of the shorter high lift jacks strapped on the back. If I was to pursue one, this would be the way I would go. But my Rig is for only going to church on Sunday with my Grandma rig. LOL.
Gator
Gator
The Most Unknown Member
2,474
10,377
Louisiana
I've had to use one to get out of the mud. I was wishing it were longer.
