I had to bolt the pieces of rubber that came with the cab kit which is located where the bottom of the window frame connects to the cab. This helps keep air out. You could use and foam rubber and screw it or double stick tape it to get the same effect. One thing I noticed about Honda cabs is to have to seal them up your self. If you don't your freeze you a?? off in the winter.
