P1000 White Lightning Build
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
@snuffnwhisky are you riding Aetna MTN with Pete on the 20th? After this ride I'm going radio silent til the Takeover or I finish a project (whichever comes first). I may have to call on you for some advice.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
If I can get out of work! Will not know until about that time.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Lets see it!
@spifyd has a bit of knowledge on the 700 with a turbo, not sure how it'd translate over to the 1000 if at all.
I might one of these days. I know some top turbo/tuning guys from owning the dragstrip plus I've done all the plumbing on a couple.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I've made a couple log manifolds from scratch for 4cyl cars. A twin should be easy lol. I'd love to hear a 1000 running right off the downpipe. That would have to sound awesome!
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Are you going to do just one disconnect? If you used two disconnects, what do you do with the sway bar?
Going to try 1 side first. Don't know if the free end will hit the a arms. Do have joints for both sides. Not in a big hurry to do it. Mine does pretty good without the swaybar. Would be nice to have it in certain situations.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Looks like the sway bar disconnects will not work without modification. Either shorten the swaybar 2.5" and use stock mounts or pivot it up and mount to the top a arm. Both sides will have to be disconnected. Not enough clearance between the a arms for full travel without hitting. It will have to be rotated up to the frame to tie it off, which there is plenty of clearance for it. I also have the SATV arms so I might have a little more clearance. Don't think I would mount to the top of a stock arm, might fold it.
Rotated up
IMG 20170214 222936935
Full compression
IMG 20170214 222919027
Full droop on the other side.
IMG 20170214 222903433
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Late update but I wrapped the header and painted the whole exhaust and heat shields and didn't seem to help heat in the front. Didn't check the back seats. Did not have my bubble wrap blanket under and up the seat but did have the plastic between the seat dynamated and a 4" fan running. Plastic between seats felt like 120 degrees. Probably going to take the wrap off.
IMG 20170218 160414626
IMG 20170218 151347766
Similar threads
Replies
Views
446
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
