P1000 White Lightning Build
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Power Commander and autotune hooked up. Fired right up and purr'ed. Haven't hooked the laptop up yet. Tried to get it as high as I could. Wires are already terminated so not much flexibility in moving it.
IMG 20170311 003104583
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I hope to never be in water that deep lol. Clean looking install.
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
My under dash storage delivered today. Also stopped by the Honda shop and looked at a 1000-3 LE. Seat felt softer and rear floorboard was different. There wasn't any covers over the dipsticks or cable adjustment box. Don't know if that's just on the 3 seat or both. Forgot to look under the hood at the air intake. The 12v plug in the lower center dash was the same with the storage underneath. Just has the mesh in front of it.
IMG 20170322 183608444
IMG 20170322 183642346 HDR
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That's on my wish list as well. Looking forward to installed pics.
Reactions: moparornocar
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
That was easy... Looks like they already had it designed for it. The bottom holes in the dash that u have to drill already has bosses where the push pins go. Probably saved it for 17 to have an "Upgrade" to brag about.
IMG 20170322 211803750
1490236151884 1674658836
An idea of capacity. 1 gallon of acetone, 1 armorall dispenser and a quart of oil.
211,608
That was easy... Looks like they already had it designed for it. The bottom holes in the dash that u have to drill already has bosses where the push pins go. Probably saved it for 17 to have an "Upgrade" to brag about. View attachment 38809
I like your labeled toggle switches. I would like to add a couple of lights to mine and a fan. But would like to get some dummy toggle switches, that are labeled, ratlin gun, perasope, torpedo and other stupid stuff. Can you get custom labeled toggle switches?
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Yes u can.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Have you done anything more with this idea?
I finished it shortly after that post. It works but not as well as I wanted. Lower gearing would help. There's not enough power to maintain rpm when climbing so you have to adjust it a lot. It does work good using it manually in rough stuff, like running down a creek, to keep from being jerky on the throttle.
Jamesgang
Jamesgang
148
297
Kitzmiller, Maryland
Would love to see some pics of what it looks like down at the peddle.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
where did you order yours? I need one of these too!
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
The foot well I just used the angle bracket that came with it. Just drilled a small hole for the cable and a bolt hole.
IMG 20170323 185802274
Throttle pedal I drilled a hole beside a bolt head and a hole through the pedal. Put the cable through the drilled bolt, bolt through pedal and tighten it up. Basically clamps the cable between the bolt head and pedal.
IMG 20170323 185748341
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
I don't know why the hell I haven't been getting notifications on your build snuff, but everything youve been doing looks badass! I need that throttle lock too! Trying to find the post on what you did for a lever.
Similar threads
Replies
Views
446
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
