P700 White smoke and loss of power
joec1056
27
40
Monroe, GA
I bought a 2016 700-4 a few weeks ago and I'm starting to get the feeling I was ripped off... It ran fine during my test drive, but now it gives off white smoke on startup and loses power at times. Seems that when I change gears or its been sitting for a few minuted that I get a bunch of smoke. Enough to wear I can't move it. If I cut if off and back on it will usually work, but this is getting really frustrating. I changed the oil and spark plugs a week or so after I got it home. Any ideas on what the issue could be?
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,117
21,308
Route 66 Oklahoma
I'm kinda old school, but in all my experience working on cars, white smoke usually meant a head gasket leaking coolant into the motor. Have you looked at the dipstick to see if the oil looks a little milky?
joec1056
27
40
Monroe, GA
I'll check that out tonight. I think you are probably right about the coolant. The coolant was low when I checked fluids after getting it home, I'll check that again tonight as well. Anyone have any experience replacing the head gasket?
SILVER_ALERT
SILVER_ALERT
3,117
21,308
Route 66 Oklahoma
Another thought, a possibility of a malfunctioning fuel injector or leaking injector seal, but I don't think you would be getting white smoke, if that were the cause.
Maybe @HondaTech is around somewhere to straighten us out.
joec1056
27
40
Monroe, GA
Just an update, check my fluid levels last night and it looks like it's leaking oil is leaking into the engine because the levels were low. Filled it back up and it ran better. Would it leak from the head gasket too?
Gator
Gator
The Most Unknown Member
2,487
10,456
Louisiana
Burning oil will be blue.
You said it smokes are you saying it is coming out the exhaust pipe?
Reactions: ChadD
joec1056
27
40
Monroe, GA
Yes, the smoke is coming out of the exhaust pipe. The smoke may be more gray than white, the kind of smoke that just kind of lingers and doesn't dissipate. Happens when I first start the sxs and when it loses power(when I am giving it gas). I should have taken a picture of it last night, I'll do that after work and post it.
I noticed when I changed the top spark plug it was pretty gunked up, I figured it was just really old but could help indicate the problem.
Reactions: ChadD
43,046
These guys are right in that traditionally, coolant is white, while oil is blue...BUT, larger doses of oil (as in smoke screen) will make the smoke look white/light blue. How does it smell?
If you do a head, make sure you check it for warpage, etc. It might make more sense to just buy new parts, depending on price.
joec1056
27
40
Monroe, GA
It doesn't have a sweet smell like people are describing with coolant leaks, more of a pungent odor. Not really sure how to describe it. I'll take some pictures of the smoke tonight, maybe what I'm considering white/gray is more of a blue color. It really spews out quite a bit when I first start the sxs then dissipates and only happens more when I lose power.
Do you think this is something I should be diving into myself or take it somewhere? I don't have much engine experience other than changing oil and standard maintenance type stuff. Just don't want to make it worse.
toddvdh
toddvdh
1,104
7,288
Green Bay, WI
Might be a dumb question, but have you checked the air filters? For both dirt or mouse houses.
Gator
Gator
2,487
10,456
Louisiana
You indicated that the smoke might be grey. That could mean something. Too much fuel will create grey to black smoke, and foul a plug.
A faulty injector
Plugged inlet filter
something in the fuel???
I'm not saying that @Smitty335 isn't onto something (or on something).
joec1056
27
40
Monroe, GA
A faulty injector
Thanks, how could I diagnose those?
I originally thought water in fuel, so I emptied the fuel tank and put fresh gas in.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,528
15,413
Ohio
Run your finger inside the tailpipe. If you are burning much oil at all it will leave a greasy residue in the exhaust. If it is burning oil my experience has been worn valve seals and or valve stems allow the oil to run down the stem of the exhaust valve and into the cylinder. I've got a 350 rancher that smokes so bad on start up you can't see around it. Once warm its tolerable. Also at times I've thought I killed it and when I pull it apart and clean the carbon build up out of the head it comes back to life. Most of my smoke is coming from worn valve stems but I also have worn rings from constant wot on long road runs.
joec1056
27
40
Monroe, GA
Thanks, I'll give that a try.
