pct
Lost in the hills
installed my super atv winch and mount fairly easy just a few short cuts that I found as it went on first you remove the bolts that attach the front diff at the top then the bottom ones
then you put the mount on just snug top and bottom plates
this is for alignment for the bottom bracket snug the bottom bracket remove the top bracket so you can
tighten the bottom bracket
now you mount the winch to the top bracket before you put the bracket on(one of the make it easier for the next guy HaHa) note when you put the top bracket with the winch on it make sure that you have it all the way up so you will have clearance on the bottom of the winchthe bracket is slotted so make sure that is all the way up
havent wired it yet but the instructions are very good will post more when i get it wired where you mount your electrics is to your own taste the angle is not bad but not much room to ingage and disengage the winch working on a easier way to do it
Hope this helps
Hope this helps
