P500 winch mount
James500
14
7
Kentucky
I have stock 2020 P500 and looking to add a winch. Do I want hi or low mount? I will not be plowing only using winch for pulling. Factory bumper.
43,590
I had the low mount and it was fine. Decision kinda got made for me, but would have preferred the high mount, as it gives a bit of protection to the lower radiator area.
Reactions: Peter_72
KYhillbilly
KYhillbilly
562
1,713
Ashland, KY
I have a KFI and its a high mount i like it because if stuck in mud its not burried and when crossing creeks it stays drier.
James500
14
7
Kentucky
Might be dumb question but does the high mount KFI or other block air flow for cooling? Do I need to be concerned?
ShotgunClay
ShotgunClay
172
594
Founders Ranch New Mexico
The possibility of the high mount blocking the radiator has been discussed here. There general opinion is that it does not. I think the P5 cooling system is typical Honda "way better than needed". I run my had in NM and the gauge never goes past 2 bars.
Timmy
Timmy
370
751
Elkview, West Virginia
I am running the KFI high mount also.
196,740
Have put mine through hell with a top mount and it's never heated up. The only P5 I've ever seen get hot was @Mudder at the Takeover. He splashed some water in there and it was good to go. I honestly think it had more to do with the bumper. 🤷‍♂️
Reactions: snakeriver
Fatsquatch
Fatsquatch
Approved Member
121,618
1,013,852
Hidden
I had my mine hot at RRB 2 or 3 weeks ago. The sprayer to clean out the rad was the ticket though. Nothing to do with the winch though as mine is not a high mount.
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
I got a Warn winch, mount, snow plow and plow mount. They mount it low. Works fine with a plow. They must have a reason ‘why low’. Maybe it was easier for them too.
