P500 Winch
RumpRocket
189
295
USA
What winch do you have?
What winch would you suggest?
What problems have you had?
Is it Water Proof?
Are they hard to install?
DaddyDubbs
DaddyDubbs
14,910
140,674
I went with the Superwinch LT4000ATV synthetic, Superwinch LT4000ATV SR - 12v - 1140230 - Several sellers on-line.
Like @trigger I have used wire rope winches in the past and kinks are a pain and frays can tear your hands or clothes up. I agree with @Bad_bowtie about running cable to battery, put the unit on stand, remove all factory skids and run battery cable is the easiest.
So far I haven't used it to pull myself out I look at it kinda like insurance, better to have and not need than need and not have.
Similar to when we lived in Michigan, if I didn't mount the 8 ft snowblower on the back of my IH-766 in early October we'd surely get a ton of snow and deep drifts. But mounted and ready to go was much easier than not mounting and trying to dig blower out of a knee deep drift to hook it up.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I plow with mine so I went synthetic, can't stand cable kinks and frays. Been using this one for two years now, pulled me out of a mud hole too.
KFI Stealth 3500 lb. Winch: SideBySideStuff.com
Any chance you could send me a picture or two close up on how the KFI mounts to the Honda Pioneer 500? Reason for asking, I added the 700 bumper to my under and now, I'm curious how this might work without the stock bumper....
Reactions: RumpRocket
Mudder
Mudder
NTC Ambassador of Walls
11,691
88,482
Badland 3500, came with switch to mount on roll cage and a handheld wired remote with plug, mounted plug in grille. It replaced first 2500 winch. Worth the $50 more for 3500, easy clutch operation with a twist. Def. go at least a 3500 size. Also like the wireless controller off internet for $15. Mounted on Strongmade bumper. Easy install. Only used for tree work so far. Someone said if no pics, then it didn’t happen, so heres a pic. LOL. Agree with running wire, (6ga. , added connection posts under hood, waterproof switched breaker (150 amp) near battery.. can throw switch to kill power when adding other stuff).
BA33CEF0 A683 4A32 A8F9 004213236B4E D71AA136 410B 428D 8E0C 27A43E93342D 3A90E6F9 CEB7 4161 87C9 611C82DBA265 A39D9BF5 0943 4944 A2E9 CB8F59C4B237
rocmar
rocmar
4,741
5,776
4 CORNERS
I got Warn 2500.. burnt up...
was installed by dealer. ..when
wife purchased for us...
so....was gonna replace..read
reviews...which are not good..
Lookin to replace. ..this spring
....but with wat....not sure
....only used to drag logs....back
to camp..
Mlaz81
40
Madison OH
  2. Other Brand
I put harbor freight badlands 5k on all my machines. They get used a lot and no failures as of yet. For 140$ on sale, they are hard to beat. A couple times a year I run the cable all the way out, take an old rag, use heavy waterproof grease and coat the entire line as someone reels it in. I've found this helps tremendously to prevent fraying. If and when it does begin to fray, I'll probably just replace it with the synthetic that harbor freight sells. I think it's around 20$
HUCK
HUCK
1,047
2,319
ARIZONA
Some with winches , some without , so far a come-along would have handled everything just fine and a few times much better . Easier to pull from the side with a come-along instead of a mounted winch . In case you lay it on it's side . Thats my 2cents worth .IMG 6090
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I have a 4000lb Warn with synthetic rope. I use it to plow snow, it's waterproof, and it's never let me down. I also have the wireless remote and highly recommend it!
I've heard good things about KFI and viper as well.
182,078
KFI mounting plate. The 700 mount should be similar.
Front sept cropped Front sept
RumpRocket
189
295
USA
I decided to go with the Superwinch 1145230 Terra 45 4500lbs with the KFI mount.....I never messed around with winches so it'll all be new to me......Thanks everyone for the feed back....I'm sure I'll be back asking for help.
Reactions: trigger
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
I have ran synthetic for years and have never dried the rope. On my ATV is the winch was under water or in the rain all the time. Not sure why except maybe to keep from smelling moldy but not sure mold would grow on sprectra, dyneema or Kevlar or effect it if it did.
RumpRocket
189
295
USA
That works for me....Thanks
AlR
AlR
470
1,166
Nanaimo, British Columbia
I put on a Superwinch Terra 3500 synthetic. I believe I’ve used it more than the average wincher... I used it to pull a walk-behind trencher 6 hours per day x 4 days. Lotsa heavy tugging and actually having to let the thing cool down occasionally. I’ve also pulled myself out of a few holes, winched more than 800 ft through deep snow with an ice-crust and dragged a Honda Rubicon up a 100 ft super steep hill after the atv cartwheeled down said-hill. I’ve never used a winch more. Really impressed with the thing. Easy to install. In fact I prefer installing it myself because I took the time to solder and shrink-wrap all the wires, greased the connections etc. I added a cheap remote control as well; it's worth it’s weight in gold. PS: I’ll never go back to steel cable.
My $0.02
RumpRocket
189
295
USA
I installed the breaker inside the battery box. Drilled a hole in the bottom and installed a rubber grommet to help keep the water out, removing the belly pans now so I can run the wires along the inside frame and zip tie them.
I'm retired so I have the time.
