P500 Winch
pFive
pFive
670
1,264
Greenwood IN
I use a cheap "Champion" and it worked well enough, but the button box itself was huge because it did not use relays. Initially I thought having no relays would reduce failures since the relays don't like to get submerged, but the switch box/remote needed 4 BIG wires ran through it and that really sucks, so I purchased a relay kit on Ebay and changed it out and it has been working for 2 seasons of harsh conditions. I also purchased a $70 winch at Xmas time from Rural king that also had a wireless remote, I figured I could use it as a backup if my Champion fails, plus I have a wireless remote kit in that box that I could add at any time) but so far so good with the cheap Champion. I have never heard much BAD about the Harbor Freight winches, I would buy one in a second.
RumpRocket
189
295
USA
My neighbor told me he started out with a cheap winch and it didn't last.....he suggested a Warn or SuperWinch.....he has a Warn now and hasn't had any problem with it....this stuff is all new to me.
I was tooling around with one of these before getting a P500.....never had any problems with it in the 3 years I had it...
80ccMotorizedBicycle a
NitroxDiver
NitroxDiver
488
918
Concord NC
I have a bad land 3500 with the badlands synthetic rope. I have worked it hard on several occasions with no problems. Once I had to winch my machine close to 100yards up an extemly steep hill to bring a deer out of the woods and the winch never gave up. Two points about this situation 1. I did let it rest a little bit while changing anchor points and 2. I didn't shoot the deer a friend did. My deer never run off and require this much stupid work to retrieve!
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
I have a Harbor Freight 2500 with remote control, it has the wire that I've ran for 2 snow seasons and has worked well. I have a KFI 72" plow -no problems. It's a pain to run the wiring but not to difficult. A wench is well worth putting on no question.
Good luck
Reactions: RumpRocket
O
oldfortyfive
608
1,386
Illinois
Good luck
got to love spell check....
RumpRocket
189
295
USA
Good luck
Some people claim to have very good luck with Harbor Freight winch's and are very happy with them.....I don't think you can beat the prices for them....I was looking at the ones in Tractor Supply too...the prices not to bad.
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
Wait for the many sales Harbor Freight has most every week, then cut out the 20% coupon then you have it at a great price.
AlR
AlR
470
1,166
Nanaimo, British Columbia
Good luck
2500lb is pretty small pulling that thing through a mud hole or up a hill. Cheaper brand would justify bigger winch, IMO.
I concur with my learned friend. A 3,500 lbs wench is probably best on a P5.
Buford
Buford
362
586
U.S.A.
Have you ever seen the fairleads that come with the Tractor Supply "Traveller" winches ? Looks like they came out of a cracker jack box :D
DaddyDubbs
DaddyDubbs
15,418
145,492
Good luck
If I was single (or if I wanted to be single again) I would certainly consider a wench. :D
What winch do you have?
What winch would you suggest?
What problems have you had?
Is it Water Proof?
Are they hard to install?
4500 Viper
The biggest you can afford
Winch was too small
Yes
No
I stuck my 1000 so bad in my back yard yesterday pulling my trailer that double lined on the first layer I was dragging my wife’s explorer and my 1500 Crew 10,000lbs combined. (Yard was wet but not muddy under the cars)
Ended up with a mini-excavator barely getting it out.
Get the biggest winch you can afford, better to have it and not need it than need it and not have it.
Mudder
Mudder
NTC/TAP Transition Member
11,882
90,580
Which ever you choose, use caution when winching for the weakest link, may be the winch mount hardware/ubolts or bumper, or the front wheel suspension if up against a rock/root or deep hole.
