After a trip to Mill Creek in Arkansas and seeing some climbs I'd like to have a safety net on, how do you use a winch from an angle without pileup? I have never liked the idea of using one without being able to level wind the cable back on. I went so far on my old Foreman as to mount a cheap winch on a pin on swinging frame with a lay down fairlead nose a foot out from the drum to always keep the drum perpendicular to the line. Only tested it and it worked but stuck out front considerably. I'm a flatlander and don't mud and would seldom have something to pull on anyway.
I am considering building a handheld unit with my old 'A' frame fairlead on it which could be hooked onto a D ring on the front or rear and have a high amp plug on both ends to power it from. I am not a rock crawler but would like something better than a come along!
