P700 Windshield Wiper specs
rogerdodger
rogerdodger
29
Does anyone have the specs on the Honda Windshield Wiper kit 0SE10-HL3-500. I'm wanting to know how long the blade length is and what the degree of reach is. 90?? 180?? Any info on this would be helpful. Tried looking online but couldn't find anything. Thank you.
Junkymac
32
19
CLE, OH
Hey RD. Sorry been meaning to measure for you. Blade length is 13.5", and reaches about 135 degrees across the windshield. Was very easy to install, once the aux panel was installed. I'm happy with it although haven't really used on a ride...only when raining while working around the yard.
Good Luck
rogerdodger
rogerdodger
29
Thank you for the information. Would you happen to be know how thick the windshield frame is where the wiper motor studs go thru. We're thinking about mounting the motor system to a different type of Honda windshield. Does it just clean the driver side or does it clean the passenger side as well.
Junkymac
32
19
CLE, OH
It's probably 1/8" thick where the stud goes thru. I have a solid Honda windshield.
It cleans passenger side too, but doesn't make a complete 180 degree sweep. As mentioned starts at top of driver's side and sweeps about 135 degrees to pass side. Might miss the top 6" or so on the top of the pass side. Hope that makes sense.
Reactions: rogerdodger
810a6fc33afb379c86a3f34e6426241c
Have to use it on glass, anything else will scratch.
