P1000m5 Windshield
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
I have a two piece poly windshield and live on a dirt road. We also do some mudding. After a year of dust and mud it was very difficult to see through. Started the process of doing a three step polish. Here are some pics. Will post more of the finished product. Let me know what you think or what you use to keep it as scratch free as possible.
20181216 154942
20181216 163737
20181216 163806
sek-hunter
sek-hunter
317
617
Looks like a definite improvement... is this the non-hard coat?
Reactions: Remington and BWAF
MMW
MMW
59
111
Arkansas
I have a two piece poly windshield and live on a dirt road. We also do some mudding. After a year of dust and mud it was very difficult to see through. Started the process of doing a three step polish. Here are some pics. Will post more of the finished product. Let me know what you think or what you use to keep it as scratch free as possible. View attachment 97911 View attachment 97912 View attachment 97913
One trick I used to do with boat windshield that were hard to through was to use pledge furniture polish. It only lasts for 3 or 4 weeks but it was a quick fix when needed.
Reactions: BWAF
BigOL3
BigOL3
2,994
8,920
Well Cecil, I will try again ......
What product are you using? I have glass on the Honda, but I have Lexan on the Takeuchi track loader and the door is getting scared.
Reactions: BWAF
SFC3
SFC3
15
19
MS
I've done headlights with the 3M kit...I bet it'd work on windshields...
597a5f92 cb88 41c1 84ac 775fab35b47f 20b4cc55bf7a2d2c8117683b2b6443366
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
C1CB949C A53E 4206 AC2C 907F69847A13
This is what I am using. I hope to finish up this weekend. Starting to get a little to cold to ride without it.
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
Sorry about that have been busy.
Reactions: BigOL3
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
Looks like it was worth the effort.
What did you use to polish the plastic?
Drill? Da? Flex polisher etc?
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
FWIW, I recommend using the same method that you would for finishing a clear coat paint job.
It’s essentially what the 3m head light kit is.
Start with 800 grit auto sand paper and work your way towards 5000 grit.
I prefer to wet sand even with the 800 as it keeps the surface cool and helps to keep the sand paper from clogging up. A da sander, drill etc can be used. Don’t get wild with the speed or pressure.
Once you get to 5000 grit the surface should be pretty darn clear. Hit it with rubbing compound and a buffer and it will be clear as glass again.
At this point you can reapply plastic protection or hit it with pledge.
