P500 Wiring a trickle charger to a KFI contactor.
idahoron
idahoron
I just got done wiring my KFI 4500 winch. I would like to put contacts on the battery to hook up a trickle charger. I'm thinking about using the KFI contactor instead of the battery. It would be much easier to plug in the trickle charger. Any reason a guy can't do that?
Reactions: BWAF
115,302
Just hook it up the the battery with A plug on the side to plug in the trickle charger. I wouldnt hook it to that contactor. Dont over think it.
pic is on my P1. Had it on my P5 too.
btw, you have 3 post since joining in 17’ and no pics
of your rig!
Pics Or It Didnt Happen!
908E2481 5F8A 4D40 B753 19BFA21D1AB6
idahoron
idahoron
It took me a long time to get one. I had an industrial accident in January 2019. After surgeries getting a utv was low on the need list. I was forced out of my job because of the accident in July 2019 afyer working there for 35 years.
I became a grave digger after that. Being a grave digger in a pandemic leaves no time to do anything. I left that job October 2021. I got my 2016 the first part of December.
We had a pretty tough winter and I haven't ridden it more than about 10 miles.
I got a new winch, and a set of wheels for Christmas. This picture was taken tge day I brought it home.
So here's my picture and my story. Not sure why that was an issue.
20211204 135931
178,016
Like Remi suggested, depending on which trickle charger you use, wire in one of these and be done with it.
5,406
24,778
It wasn't an issue, asking for pics is common internet behavior - everybody loves pictures. 😎
Although an unusual hook up, you can connect to any positive and ground connections that are always connected to the battery.
Reactions: idahoron
idahoron
idahoron
I'm not sure yet if I'm going to leave the rack on. The guy I got this buggy from was a miner and carried gear to his claim. I kind of like it but my dog box won't fit on the back.
I'm a little concerned that the higher weight might make it tippy.
5,406
24,778
Usable space is hard to come by, you could keep lighter stuff up there. However, the dog gets priority so I'd have to extend it up or build a box to fit under it.
driller
32
146
WV
When I brought my P520 home, I noticed the dealer had wired a 2-pin SAE pigtail coming out of the battery box. Any of my several Battery Tenders will plug right in.
Thanks @trigger for the link to the panel mount socket. I plan to get one and wire it in place when I do my auxiliary battery installation. 👍
Reactions: trigger
