Multi Wiring accessories help
F
Firedad
46
103
Reno, NV
  1. Talon X4
Bought rigid d-ss cubes, KC cyclones and a backup/rear view camera. I need help with how I should be installing. I see the switch controller option and that looks good. What do you thing about auxbeam or rough country light controller? Need help cause I can’t seem to make sense of anything.
115,707
Have u tried to search this and the controler your asking about? Theres a few threads on the controller And alot on many different ways to wire your stuff up. I have the Auxbeam controller in my Talon. Its the most easy way to wire up your accessories. Just buy it and there is very easy instructions how to wire it up. If you want to get more complex and loose some hair, do the other methods and search it. Heres just one of the Auxbeam threads Found in the search.
F
Firedad
46
103
Reno, NV
  1. Talon X4
You're assuming he HAS hair. His username includes 'dad'. I'm betting it's thinning already. LOL. J/K.
True.
i did rush to post this because I’m stressed for time. I did search here, another forum and the web but those seemed to be in a different language. As you said buy it and follow the simple directions. That’s what I expected from the lights and camera but they basically say no more than “mount and connect”. 🤕
F
Firedad
46
103
Reno, NV
  1. Talon X4
If I buy the auxbeam or similar product will I need anything else or will this product do everything I need to install and control my accessories?
F
Firedad
46
103
Reno, NV
  1. Talon X4
I bought the rough country 8 gang switch. Didn’t realize they were here locally so I went shopping. I got it installed but the key on part didn’t work for some reason. It just stays on. The circuit breaker has an off switch so that’s how I’ll deal with that for now.
F
Firedad
46
103
Reno, NV
  1. Talon X4
In a different forum I was told I may have wired it wrong. The power doesn’t go off with the key. Going to bring it to work tomorrow so I can play with it and finish the install of the camera and lights. That way too I can take a pic to see if anyone can see where I went wrong.
66,869
It's most definitely wired wrong.
The little red wire is what we need to be looking at. It needs to be on either a key-on or switched source.
This is what controls the unit.
Key-on source will go on and off with the key.
Switched source you can control it but don't forget to turn it off.
I have both using a special switch.
Ok.
Thanks.
F
Firedad
46
103
Reno, NV
  1. Talon X4
This is the little red wire you speak of? The directions said to connect the white wire to the keyed on white/black stripe wire and the red goes to power source. So that’s what I did but I would like to follow your direction but just to be sure I understand here’s a pic. I’m about as ignorant as they come when talking wiring so please help.
Image Image
66,869
You almost have it.
But the white wire is a dimmer wire. You don't really need this. It can be cut off.
Hook the red wire to where the white one is and your all set.
Reactions: Remington
F
Firedad
46
103
Reno, NV
  1. Talon X4
Tomorrow I’ll post pics but I’m done for now. I installed upper doors, lower doors, glass windshield, rear windshield, and thanks to this forum and especially Hondasxs I’m now done with the 8 gang switch, KC cyclones for rear and side scene lights and rigid d-ss pods. Except for the money spent it’s been fun building this thing. Thanks for the help
