Got some led lights. Mounted them wired them straight to battery. How would I wore them in where they would only come on when key is turned on to prevent being left on with machine not running.
Quick and easy KEY ON Accessory power source for your Honda Pioneer. PLUG-N-PLAY No Splicing of wires. No Tapping of wires. 3ft lead easily reaches anywhere under the hood. This kit plugs inline with OEM harness and provides a 12v positive lead. Use this Key-On Accessory wire to run the...
unplug it from connector mounted on frame rail, then plug that into your harness. Its connected to a dummy plug that you must separate and then plug to your new harness.
