P1000 Wiring up 7 pin DPDT switch
CoachRoss07
CoachRoss07
15
17
Arkansas
Hey all,
I am sure someone has already posted this somewhere or asked this question. But I'm wanting to have key on power as well as key off power. So how would I power my switch into my stinger isolator/relay. The switch I'm using has 7 pins. 7 being ground. Would I run a power wire from my 2nd battery and from my acc fuse to the switch then run then what next? Kind of confused on how I would wire it honestly.
S l400 1
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
so your wanting power for when the key is off but want to wire it up to when the key is on its automatic on?
CoachRoss07
CoachRoss07
15
17
Arkansas
I want to wire it where even when the key is on I can turn the switch to off and shut everything off or I can switch it on with key on and power it on. But I can also turn the key off and switch it to the other side of switch and power my accessories.
Kindve using it as a master switch essentially
CoachRoss07
CoachRoss07
15
17
Arkansas
This is what I am dreaming of here lol. NCDragon21 on YouTube it will get you an idea of what I want to do.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
oh yeah just run the one from the key switch to 1 side and battery to the other side . then run a both to a the relay or what ever your powering. you can jump the wire over and just leave the switch with 1 wire. if i remember correctly. i did something similar a while back. View attachment 174844
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
wait that way he doesnt have to jump from 2 over does he since hes running everything on 1 side of the switch?
67,170
2 is just switch light control.
Which ever way it is flipped is what light will be on.
Reactions: TripleB
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
yeah dont do it my way i forgot about dual polarity with a constant ground set up. do it his way.
Reactions: Haldog77
CoachRoss07
CoachRoss07
15
17
Arkansas
Another way is to NOT jump to 2.
Instead have the power return from the fuse box then jump around to all your switches.
So is would still be ok to wire it as you orginally stated though?
Jump 5 to 2 then run a wire from those two to the stinger isolator?
Just trying to be clear so I can understand lol
67,170
Yes.
That would trigger your relay 2 ways.
Key-on or key-off, and middle would be OFF.
CoachRoss07
CoachRoss07
15
17
Arkansas
Thanks alan very much man. I appreciate your fast response buddy. This website has been a lifesaver for me because of people like you. Thanks again buddy!
Reactions: TripleB
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
no problem just dont follow my photo. for some reason i was thinking a dual polarity constant ground and was ignoring half the diagram. although i think itll still work that way but the lights might not be correct. honda sxs got this one. for ya.
67,170
Ya. Top light would be on both ways.
But the relay would trigger right.
TripleB
TripleB
15,618
140,489
Caryville, Tennessee
I still don’t understand how to wire this switch correctly? Pls help
That picture is about as simple as u can make it. 7 goes to ground. 4 goes to key on power source. 6 goes straight to your second battery. 2 jumps to 5 then goes to small post on your stinger. Other small post on stinger goes to ground. One big post on your stinger goes to 2nd battery. The other big post on your stinger goes to fuse block.
