P700 Wont move or shift
T
Travis2308
10
Tx
2015 P700 with about 800 miles on it. Bought used with 600 miles a few months ago. Great condition, original CV axles etc. The bike worked fine for the last couple months but now will barely move.
40 plus degree temps and i let it warm up a couple minutes, stick it in gear and the bike will move maybe 10 feet, sometimes 20 sometimes not at all. Will go all the way to the rev limiter while barely moving. If i wait 5 more minutes it will run up fine in first gear and hit the rev limiter (won't shift into 2nd). 5 minutes later it will run up fine in 2nd and hit the rev limiter. After 15 minutes of riding it finally will shift into 3rd.
No clutch burning smell or anything. Bike shifts into D N R perfectly. Oil is clean and full. I read about some valve on the driver's side engine that adjusts the oil bypass to the clutch but haven't checked for it yet. Just wanted to see if anyone knows of anything else to check.
Thanks
Reactions: 15pioneer700
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Unless you did the work, who knows what kind/weight oil the former owner used in the machine. Personally, I would do a baseline start with it and put in all OEM Honda products and give it a try. If a fresh correct oil change doesn't help, I would look adjusting the clutch.
Reactions: swsebek
swsebek
swsebek
2,854
5,835
pa
I agree with outdoors on the oil and start fresh knowing some meathead didn't put in the wrong stuff. You have a torque converter so no clutch adjustment. But almost always in these 700s it's the oil or not enough oil. The wrong oil or just a little low has and effect.also check air cleaner on these 700s. Almost always they need cleaned.
A baseline start means--- oil and filter,air cleaner, spark plug, and differentials..It's 50 bucks well spent.
T
Travis2308
10
Tx
Well instead of writing all that I should have just checked the oil again. Was two quarts low in just one week (about 10 hrs run time) no oil on the ground so now I've got to figure out where all the oil is going.
swsebek
swsebek
2,854
5,835
pa
Make sure the ol girl is level when you check her. I run my a little above the high mark.. and now if I was you I would do as stated above and have a piece of mind knowing it's ok. Ask any questions you have...
Reactions: Mudwing
alloutdoors
alloutdoors
1,022
2,184
US
I didn't realize no clutch to adjust,
Check the air box....
