ehart814
Hoping someone here could help me out a bit... @HondaTech ???
Long story short, my cousin has a 2016 Wolverine and after severely overheating it many times, they ruined the top end. Top ring seized in piston...ruined head...melted three sensors. So we rebuilt the top end and it runs perfect now.
Trying to get all the bugs worked out. We rode the other day and he kept having trouble starting it. We had just installed a new battery and tested it to make sure it's good.
He neglected to tell me that his check engine light was coming on and displaying a message "low battery". So I was thinking maybe the stator got cooked when it overheated.
Then he tells me that even before they toasted it, the voltage gauge was running about 12.5-12.8 volts max.
Tested it last night. Key off - voltage is around 12. Yamaha troubleshooting says hold rpms at 5000 and it should read 14 volts. If not 14 volts, replace regulator rectifier. Tested and got 12.5 volts. Lights on, the voltage drops to around 11.8-12 volts. The voltage does rise slightly when rpms increase, but not enough. Have not tested stator yet. Need to unplug and check resistance between the wires.
It appears that the stator is trying to charge, but the voltage is too low. Thinking / hoping it's the regulator/rectifier. Anyone have any advice?
