P700 Pioneer 700 - Wire Diagram - in color.
64,288
fishin2Dmax
fishin2Dmax
186
32
Very Nice.
Without the color, I think it would be nearly impossible to trace the wires in the diagram. Thanks for the diagram, at some point it may becoming invaluable.
concop13
How do you become a supporting member?
W
Williams13
5
Is there a better image electrical diagram for the 2015 pioneer 700? I can not read the gauge wire and specific info on this diagram. Thanks
Joe
mattkin
How do I become a supporting member to read the high rez diagram?
d_b
d_b
302
240
Need to make these 11x14 laminated AND SELL THEM.
eastenn
eastenn
220
469
Bristol TN
www.fb.com
I'm not sure where the best place to add this info is, but I had a slightly difficult time wiring in my backup lights. I am using a pretty standard 4 pin relay. I tried tapping the gray wire that runs from the R Gear Position Sensor to my trigger pin (86) on the relay, with the other pins wires as normal
30 - 12v +
85 - - ground
87 - + out to my lights
Well as soon as I would put it in reverse it would kick something out, lights wouldn't come on, and on my digital display instead of "R" it would read "-".
Upon further investigation, the gray R GPS wire is a ground signal for the reverse actuator. So in order for the relay to work correctly, simply jump the 30 pin to 85. So should be as follows..
30 - 12v +
85 - 12v +
86 - - tap from gray wire to R GPS
87 - + out to reverse lights.
In that configuration works just like I expected it to do the first time :)
Also, the gray wire to tap is under the seat beside starter relay going into the PCM.
Reactions: tjoreo
64,288
Yep, you can't ground the gray wire outside its own circuit, You will end up with a fault as you experienced.
It should be used as a ground trigger only.
ALSO... It is possible to experience that same gray wire lighting up a test light when NOT in reverse. Don't take this as a false positive.
eastenn
eastenn
220
469
Bristol TN
www.fb.com
You're right. I was getting some funny readings off it with my volt meter and actually thought it may not be the reverse wire.
