P700 Pioneer 700 with Can-Am Commander Shocks
G
green02crew
158
54
I offered 250 and he immediately rejected saying the are over 200 a piece brand new, I will pay the 300 cause I really want to do this modification. Plus like y'all say you get better then or equal too ride as the Fox shocks for way less and a lift kit.
Usually just under $90 per shock new. Then add springs and associated hardware, they do get expensive new.
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
I agree, best upgrade on the 700. It will be worth every pennie. don't forget to order the bushing you need for the rear shocks. plus you are going to gain about 2 inchs of lift.
Reactions: jcash3485
Gator
Gator
The Most Unknown Member
2,475
10,395
Louisiana
Do you have your tubing? I might still have the left overs from my install.
jcash3485
47
21
Florida
I had a pm saying someone had some tubing. Waiting to hear back from him. If not I'll be looking for some. I also need the bushings. What the best place to get them?
jcash3485
47
21
Florida
And just to check I understand, the fronts don't need bushings replaced just the rears?
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
Fronts are direct replacements, no modifications needed.
The rears will need new bushings and steel sleaves
Sent from my SAMSUNG-SM-N910A using Tapatalk
jcash3485
47
21
Florida
Copy that. And the sleeves are the tubing y'all speak of?
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
Yes the Honda bolts are larger diameter. So you replace the bushings and the sleeves to acomidate the original bolts.
I jacked up the front and put on jackstands. The after removing the tire and shocks, with just a little persuasion I was able to reinstall original bolts.
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
5ac01d19c1b44bbf854d9fc0681c4e7fE92818301896a27f400df8be67652e96
jcash3485
47
21
Florida
Ok, thanks.
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
The rears are a little more challenging, have to unhook sway bar and upper A arm connection. It would be a lot easier if you could compress the springs a little. A long lineup punch will help a LOT!
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
00a5650b389c954f85c77709dc699f32
Here's the rears side by side.
jcash3485
47
21
Florida
We need a youtube video on this (for the rears) lol. Is there not a way to compress the spring during installation?
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
Not that I had available at the time. There isn't a lot of room to work there. Maybe compress the springs and secure with big tye wraps and then cut after install.
Vato
Vato
180
159
Buy them. they are so much better than stock and as good as the Fox Shocks plus a bonus lift...just ask Spifid. He drove mine around one night for a couple of hours with the xt's on the front only and like them! I sure like them a lot.
But I sure liked wheeling his turbo charged fox shocks equipped 700....almost didn't give it back to him!
