P700 Pioneer 700 with Can-Am Commander Shocks
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Anyone had an axle boot problems since the commander shock instalation?
Clean cut as if some one used a razor blade on it. LR Axle
20160923 085054 20160923 085045
7,145
27,183
No yet, but let me know if I need to get a replacement boot Kit to keep on hand?
Sent from my SAMSUNG-SM-N930A using Tapatalk
7,145
27,183
Couldnt do that with a chop top!
SundayRdr
SundayRdr
575
1,179
McMinville Tn
I cant find it but I seen a axle boot bag. It was a bag that you wrapped around your axles torn boot and it kept you from ruining the bearings in the cv joint.
scott
scott
1,212
1,354
lyman, South Carolina
I will not have time to get the sleeve material here by Friday to switch on my can am shock. Is there anyway i could do it different on buy the stuff local to do it. Got to figure out something or i'll only have the front shocks on..
7,145
27,183
Scott how soon do you need to receive them to be able to install before you leave? I ordered a few extra and I can FedEx or UPS them to you and have them by Monday Tuesday at the latest.
scott
scott
1,212
1,354
Leaving Friday morning the 30th.
7,145
27,183
Let me see if I can get something to you soon enough that you can get them installed.
scott
scott
1,212
1,354
The shocks will not get here until probably Thursday so I'm probably not going to have time to do it anyways before the ride. How long does it take to do? Just doing the front will help a lot,
7,145
27,183
Rears took me about an hour and a half. But the fronts will make a huge difference. I did my fronts first and then the rears about a month later.
Reactions: scott
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
View attachment 22771 View attachment 22772
I don't think this is a common problem. I have only put about 50 miles on mine with the Can-Am shocks. But I haven't heard anyone else associate torn boots with the shocks.
F
Festus
0
Texas
Im looking for these commander shocks with no luck. Mabe ya can help me out with this. Thanks
scott
scott
1,212
1,354
Can you not get the rear shocks on before Friday?
No don't have the stuff to change out the springs. I wish I could because that extra weight of gear is going to suck. For ground clearance. I'm going to put some stuff in front seat I guess.
Reactions: joeymt33
