“Clutch’s Basket” build
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Got both water tanks in. I measured actual volume to be 26/40 so 66gal. Simply used 2x2 screwed down with expanding foam for cushion. Use foam for lots to keep things tight through vibrations, worked excellent in the bus. Also used some bubble wrap at the base.
Adjusted two of the water level meters, med to high spot on small tank and added a new high level into the other tank for fairly accurate readings.
The pump is adjustable and easy access. Water fill is in as are both air vent tubes. Outdoor shower fixture (black plastic as with everything else) is in but none of the pressured water is installed yet.
View attachment 79453 View attachment 79454 View attachment 79455
Fill was placed as high as is comfortable to fill and the shower is out of kids reach by themselves but at a comfortable hight for usage.
Had to change out water intake so it’ll now fill at the base from the larger tank to the smaller one. Also water drain spot for both tanks, the T coming off.
Looking good
322,690
f*** a duck! Plumbing was supposed to be fully used from camper but it needs to fit better. Camping World sucks! If you’re not buying a new Rv you are nothing, went to a smaller place and immediate help. 60$ for all fittings and some more pipe. Could’ve started over with Pex but way too much money.
Back going! Water pressure going in!
BE4BF904 EBD5 4334 97E4 424F87490AFC
69,057
Home depot 3/8 pex and sharkbite fittings.
322,690
Ya they just didn’t cross over great. Would’ve had to change everything out. It’s good now, also found Ace has parts, I’d go Pex if started from scratch but saving all we can. Sure could’ve used you tonight for routing and running lines!
Got bathroom sink,toilet,shower and outside shower hooked up and pressure tested tonight. Hot water tank and kitchen sink to go for water.
Filled tanks all good and hold when over pressurized. Going to pull some back out and start getting this all solid.
87D975DD B67C 4DC8 8A92 112F97AA4501
