It's a 80 amp solenoidI think you'll be fine if you're fuse panel stays at or under 100 amps. What size is the solenoid?
Take a look at the table in Mudders post a little higher up. Not sure what your anticipated load will actually be, but 8 gauge is smaller than any of the wire sizes listed, and it is too small for the full load 80 amps.Would 8 awg work from battery to solenoid to fuse panel?
Al the solenoid will power will be my switch panelTake a look at the table in Mudders post a little higher up. Not sure what your anticipated load will actually be, but 8 gauge is smaller than any of the wire sizes listed, and it is too small for the full load 80 amps.
Rule of thumb to determine your full load, Add up all of the devices wattages and divide by 12 volts to get the amps.
If you exceed the current (amps) for the wire size two problems can occur. First the voltage the devices see after the fuse blocks will drop. This can cause the devices to pull more than their rated current and possibly burn them up.
Second on a severe current overload the wire can overheat enough to damage it and possibly cause a fire. This is more likely with a short than a normal overload, but happens. Good example of this is a house fire with too many devices such as space heaters plugged into an extension cord that overheats and catches fire.
For the run you mention, I'd go with the correct wire size from Mudders table, for 100 amps either 6 gauge or 4 gauge depending on the total distance between the solenoid and fuse panel.
If the run is really short and you are not coming close to the 80 amps your solenoid can switch you may get away with 8 gauge, but for the small differential in price I'd go with the larger wire (smaller wire gauge). Keep in mind that more accessories may be in your future!
i was gonna use solenoid to power a master switch. I have a 12 way fuse panel rated for 100 watt I'm gonna get #6 gauge wire thinks this will be ok? All I plan on running is Noam nutv5-s stereo 50 inch light bar side lights and small reverse lights for when riding comes to a halt because of thirst! Maybe Dome lightsMy agreeing with him using 8 AWG was based on my assumption that he just running sub-80 amp total accessories via the 80 amp solenoid to a comparable 80 amp fuse panel. The winch has to be wired directly to the battery for maximum effectiveness and safety. I agree, 6 AWG should be the standard and I run a bussman 100 amp circuit breaker but that's just me. I don't think any of my 6 AWG wire are more than 2 feet long on my pioneer except maybe the two lines going to the winch. They are like 2.5 feet?
So both wires go to master switch?There’s just two small wires from the solenoid that open/close the flow. They go to the switch.
I must have over looked input wire size when I ordered the fuse panel I just got it in mail today here is the specs on the fuse panel ? It says 30amps per circuit? Think this will be ok to run above mentioned acc.??My agreeing with him using 8 AWG was based on my assumption that he just running sub-80 amp total accessories via the 80 amp solenoid to a comparable 80 amp fuse panel. The winch has to be wired directly to the battery for maximum effectiveness and safety. I agree, 6 AWG should be the standard and I run a bussman 100 amp circuit breaker but that's just me. I don't think any of my 6 AWG wire are more than 2 feet long on my pioneer except maybe the two lines going to the winch. They are like 2.5 feet?
Yes.. both small wires on master switch. Both battery wires on the solenoid.So both wires go to master switch?
Dang the asparagus flush worked, now you are making since! HA! Come on guys, we've got to get JTW back to where he was, this touchy, feely thing makes me uncomfortable about JTW, think he might have done too much asparagus for his own good! HA!Yes.. both small wires on master switch. Both battery wires on the solenoid.
I must have over looked input wire size when I ordered the fuse panel I just got it in mail today here is the specs on the fuse panel ? It says 30amps per circuit? Think this will be ok to run above mentioned acc.?? View attachment 70286
The only acc I have right now is Noam nutv5/ s radio not sure on the amps it will draw but I think it has in line fuse alreadyHow many amps will each item draw?
