P1000m5 1000-5 Rear Door Inside Storage Modification
O2bsmitty
O2bsmitty
298
659
Illinois
If the plastic wears out a small set of hinges could be used. Also a 3/4" or 1" flat aluminum could be added inside the opening for a tighter seal and more secure lock. I won't be going to that extreme. But a person could. After doing this if Big H would take this idea and make doors for this application wonders could be done.
Jstark45xd
Jstark45xd
5
Gabbs, nv
Ok fellas. First one done. Had a little trouble with alignment and still not perfect but close enough to get latched. Did something a little different to what I believe will help seal. I cut partially (not all the way thru) with cut off wheel which heated the plastic and folded it to make a hinge on bottom of cut out. If It doesn't break in time it should be easier to seal from dust. Also if this works and you want to lock it a simple cheap cam lock will work on it.
View attachment 77567 View attachment 77568 View attachment 77569 View attachment 77570 View attachment 77571
That is a great idea and should help cut down on dust like you said! Thank you!
Reactions: BWAF
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Went to town this morning looking for something to plug the remaining bolt holes. Didnt find anything to my liking so i made my own
Had a bunch of these layin around
20180602 155904
Put throught the panel and put a 5/16 washer on the backside. Then i cut off the excess so it wouldnt hit inside the door.
Lastly i took an old flatblade screw driver and heated it with a torch and melted the remaining push clip to make it solid.
20180602 155849
Final product...im happy with the outcome. I also added another latch to the top for a total of 3.
20180602 155836
115,808
Sweet my man! Just what I was thinking of doing. Glad you tried it first :D
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Very clean nice job
Reactions: GlockMeister
Looks great!!
O2bsmitty
O2bsmitty
298
659
Illinois
Now Im
looks nice. Can't wait till I get my latches. I was thinking 3 latches also.
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
On the driver side I put two synthetic ropes. One is a 50’ winch line replacement and the other is a 75’ recovery rope.
If the area is big enough I may make one of these rear areas a designated First Aid kit area. May put red buttons to release and a first aid cross on the panel itself. - need to get doing some cutting.
O2bsmitty
O2bsmitty
298
659
Illinois
Ok maybe I do need more storage. I do like this idea.
Reactions: JTW and BWAF
