I know the pictures and statements are jumbled up on this thread it was a merged thread so it doesn't flow as well as it could.
Step by step
how I did it)
1)Remove the factory plastics.
2)Place hinge along the lower portion shown in this picture there is a ridge inline with the center of the hole on the left side of hinge in this picture
3)Trim the ridge flush with a razor knife
4) Install hinge using rivets
5) Cut the holes out of the doors as shown in the picture above with saw(any woodworking blade will do.
6)Place painters tape on factory door in area of the hinge.
7)Remount factory plastic with factory bolts
8)Mark position of the hinge WELL
9)Remove the plastic
10)Might need help with this step, line the hinge up with the marks you made on the tape and drill a hole into the door toward one end of the hinge. Insert rivet (use a rivet washer on the back) and fasten the hinge to the door. Repeat on other end so that the holes you just drilled are both guaranteed to line up.
11) Check to make sure all the factory holes line up when the panel is closed and you can get the bolts in, if so drill holes for the remaining rivets and fasten to the door.
12)Lather rinse and repeat on the opposite door.
