FYI, this is off the 2022 diagram. 2023 should be simualr.
Did you find the solution?Has anyone seen or know of an illuminated headlight switch that will replace the large toggle switch on the P1000-6 ? I don't understand why Honda would install a non-lit headlight dimmer switch. Kind of hard to find in the dark. I've seen some on amazon for the CanAm that I could use with the Club oversized switch blank, but i'm not sure about the wiring since the stock switch is not illuminated. Any electrical Gurus out there that can help ?
I have the Forester Illuminated switch on my wokbench now. It is a five wire switch vs the 3 wire non-illuminated. 3 of the wires match on both switches. The other 2 require a hot and a ground to light the switch. Im going to cut off the three wire stock plug and solder it to the 5 wire switch. The extra 2 wires will be wired to a keyed hot and the other grounded. I'll let everyone know if it works out. Have been busy with other projects but it's next on the list.
LE harness be made to work?
Just Spittballing with no wire diagram in front of me.
Nothing wrong with troubleshooting ideas, it’s how we got men on the moon; one idea after another, some worked, some didn’t.Sorry for the troubleshooting squirrel.. thanks
[Can you take a picture of the 5 wire plug.
I may be able to get sometime to match
TWSSYou just have to keep fiddling with it and it will pop out.
I hooked up the illuminated switch. Works great. Thank you! Do you know if they make an illuminated switch for the AT/MT switch?Finished installing illuminated headlight switch today. Clipped the plug off both switches an soldered the illuminated switch to the plug of the non-illuminated switch to keep it stock. Matched up the blue, black and yellow wires. Wired the hot wire of the light (white with black stripe) to switched power (cigarette lighter) and grounded the white wire with blue stripe. Everything works as it should and you can now see to dim the lights ! Just like it should have come from the factory !
View attachment 377104 View attachment 377105 View attachment 377106 View attachment 377107 View attachment 377108 View attachment 377109
That would be great. Even if the group could find the different "type" of switches (momentary contact, 3-selection, etc.) then attempt to dissassemble them and swap the front of the switch so we could make any of the large OEM switches backlit!I hooked up the illuminated switch. Works great. Thank you! Do you know if they make an illuminated switch for the AT/MT switch?
Appreciate the info. Do you know where I might could find the part number for the switch?I do believe all the switches are avaliable illuminated. The trail/forest models and old LE/SE models had them.
