It's been a while since I posted so I figured I'd share a few experiences..
Current mileage 1400 mi
Ownership 1 yr 2 months
Tires are less than 50%
Front axle broke at 1300 miles and was on backorder for 2 months. So I cut the shaft off and made it work in 2wd. My buddies axle broke at 80 miles as well. ($135)
Water pump was leaking out of weep hole and had to replace 1 month out of warranty. My other buddies leaked at 1100 miles too. ($135)
Installed two boss atv20 on roll bar with ratchet straps ($250)...amazing sound. DO NOT buy the Bluetooth model!
Adjusted valves 2X
Oil change 4x
New air oem air filter at 1400 mi ($10)
12 inch led light bar ($120)
Canvas roof oem ($120)
Hardcoat windshield oem ($350)
4500 lb promark offroad synthetic winch and cycle country mount ($360)
Cycle country 72 inch plow front mount ($760)
Rear 6inch led ($25)
1 set front and rear pads (150)
6 gang marine grade dash panel ($60)
I haven't used the winch or plow yet. Just purchased both.
I think that's it for now. Will update once plow is used
Adjusted valves 2X
Oil change 4x
