15 inch 6+1 offset
Dankathy
286
822
So, who makes a non bead lock 15 inch wheel with a 6+1 offset? I put the tusk terabites on sti hd9 wheels just for the looks and gave away the factory wheels. Cannot stop the bead lock leaks. Have worked on them myself as well as a local tire shop. Yes, they have been dunked repeatedly and the leaks are in the bead locks. This isn't a pound a week, it's two go flat overnight and two loose 3-4lbs overnight. Like the tires other than that. Need to stay at this offset to fit in the enclosed trailer with all the other junk i seem to have to take along!
Have you tried bead sealer ?
Also are you following the installation method for beadlocks or are you hitting it clockwise with an impact?
not trying to convince you to go beadlock but use what you’ve already got.
You HAVE to get the bead in place correctly or there will be a spot where there is extra bead in a lump it’s best to tighten it down hand tight (no ratchet) in a 4-point pattern then split the difference to fill in the remaining bolt holes. Then hit that a little tighter with a ratchet (most have torque specs included for this)
i have always had success with airing them to 25psi, hearing the leaks, and using a ratchet to seal them.
The tire shop MAY have messed up the bead? Use the bead sealer if the first method doesn’t work while repeating it.
I had two beadlocks out of eight on dual beadlocks that never would seal correct. I hit those two with slime and it fixed them.
I have a set now that has been sitting in my garage since early February or March and they haven’t lost any air and don’t have bead sealer or slime. I was very careful getting them on not to cut the bead with tools or the wheel itself.
Reactions: Moab_Marty
5,031
22,489
I'm about to buy the HD9 wheels for my Talon and know nothing about beadlocks other than the idea behind them. Can I mount my own tires 'easily' with beadlocks (does one bead remove)? Someone suggested RTV as a bead sealer but I'm concerned about it skimming over before I can get the bead tightened - is there a 'real' bead sealer that won't skim over before tightened? Redundant question - will the bead sealer pretty much solve the 'beadlock leak' ?
fwiw: although I'm competent mechanically, I'm north of 70 and don't enjoy constant maintenance anymore, I just wanna ride (why I bought a Honda). A perpetually leaking set of wheels will eventually 'catch me out' and I'd like for that to NOT happen. (yes, I carry a pump)
Reactions: IDIOT
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
System 3 SB-4
These are what I just bought for my Talon. 6+1 offset.
Reactions: IDIOT
Xtra Seal Tire Bead Sealer 32 oz Black w/Brush Top Can PRO Quart Amazon.com: Xtra Seal Tire Bead Sealer 32 oz Black w/Brush Top Can PRO Quart: Industrial & Scientific
Yes you can install them yourself with a good air compressor and a 5gallon bucket.
get the tire on the wheel and the beadlock seater the place the whole thing on the 5gallon bucket beadlock up so you can force the tire down to the bead then seat the bead using the air compressor. A little dish soapmixed with water will help it slide on and seat with a loud pop.
Reactions: CID and Razorback
Dankathy
286
822
All good points here. Yes, i have used bead sealer. No, i am not going to use silicone, liquid nails, jb weld etc to try to make a bad fit up work. Yes, i understand diametrically opposite tightening by hand only. When i had the tires off the wheels i installed the rings and measured the grooves and given that they were all the same i dont suspect the wheels. The tires were reinstalled on different wheels with the opposite bead ring presented to the bead lock. The rate of leakage followed the tire, not the wheel. I don't know how to accurately measure the bead ring of the tires, so i am condemning them by default
Reactions: ohanacreek
like I said I had that problem and I slimed them as a LAST resort to solve it and they never leaked down after that.
Razorback
Razorback
397
999
Van Buren, AR
I have the same tires on System 3 SB4 beadlocks. Haven't had a leak in 5 months.
Screenshot 20200717 132309 Amazon Shopping
Reactions: Landman
Mopower58
Mopower58
CST is the Best!
70,318
645,513
Crystal Springs,Ms.
I never had beadlocks but I have had great success with slime over a variety of tire/wheel combinations, all of them being used off-road. Almost all were slow leaks.
Reactions: Moab_Marty and GWH
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
a great product for tire lube is armor all.
(slides on nice and leaves it pretty) :)
  • Haha
I've installed several System3 Beadlock wheels and never had any leak complaints so far.
Reactions: IDIOT
5,031
22,489
The draw to the STI HD9 wheels is that the 6+1 fronts and 4+3 rears result in a fairly equal F/R track width on our Talons. Do you know if System 3 offer a similar set-up?
PaulF
PaulF
1,462
4,810
I had the same problem and it gets worse (and exponentially more annoying) as time goes on. It is not the wheels, it is the TerraBites. The inside of the bead is so roughly molded, they won't seal properly on beadlocks, even with all the bead sealer in the world. I also didn't want to mess with silicone and all the other "suggestions". You are not the first or last person that will have problems with TerraBites on beadlocks.
Never could solve it so I put tubes in mine for now. Most likely regret this move but it has worked out fine for now, time will tell.
The closest non-beadlock wheels to the 50 mm offset of the HD-9 are...
System 3 ST-3 at 40 mm.
Some of the STI HD-10 at 40 mm.
Those will make you 20 mm (about 3/4') wider overall over the HD-9's
Reactions: CID
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I just installed system 3 6-1 fronts and 4-3 rears with 9.5” wide tires.
all the math and guessing goes out the window because after install my machine is exactly 64” wide front and rear.
measured outside of lug to outside of lug.
drove it around for 5 minutes and coasted to a stpo before measuring.
Reactions: CID
Dankathy
286
822
This is what i believe on the tires, and the answers i was looking for on wheels. The terrabites are about 50% tread left. I think i will replace them ( bfg km3 ), sell the terrabites for whatever i can get and move on. Thanks
Reactions: CID
5,031
22,489
Thank you, gentlemen - that's a treasure of information. I believe that beadlocks are necessary for my intended use, at 12 pounds with stock tires, I'm constantly aware of loading the outside of the tires and I would like to be under 10 pounds, for both traction and comfort. 30" TerraBites were the tire tire I had intended on buying - light(ish), versatile, low cost, long life. :( Oh well, back to the tire threads. :oops:
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
check out the new system 3 XTR370
like a terriblebite but tough and high quality.
lots of guys running them in AK with good reports.
5,031
22,489
Bummer, they don't have a 30x10-15.
30 because I have about an inch before the top hits the garage door, not willing to air down every time I put it in the garage (where it lives). 14" rims have possible clearance issues with suspension parts.
PaulF
PaulF
1,462
4,810
30 because I have about an inch before the top hits the garage door, not willing to air down every time I put it in the garage )where it lives). 14" rims have possible clearance issues with suspension parts.
They are coming!!!...
1595105957275
