One of the ranch's 700s caught fire after an extended hard run between pastures. Thatch was burning between the engine and the fuel tank on top of the wiring harness. Cowboy said buggy was running while he was spreading the fire around to get it out.. he said when he was done it had quit running. Fire had melted the insulation off of about 23 wires allowing them to get together. Most looked to be the smaller 18-20 ga. wires. I spliced and repaired the harness. Following that when I tried to start the machine, I had no spark and no injector pulse. Checked everything again and had discussion with our SXS Club Honda Tech. Replaced ECU and still no start..Replaced the stator/pickup and still no start.. Finally, after thinking the resistance might have been to high in the repair wire I used, I replaced the entire harness. Same thing, No spark and no injector pulse. Is there anything inside these systems that will cause this. One of the sensors maybe got a little voltage or something and telling the ecu to shut down. BTW, the dash functions as it should and shows no codes. @HondaTech may see this and chime in but at this point $1k+ into this thing and then have to take to the dealer will make me puke. Maybe ,for different reasons, somebody has run into this before..
Thanks
Billy
Thanks
Billy
