18” light bar on stock X4 bumper
34,174
Due to the fact that my Talon fits the toy hauler with just a few inches to spare, my light bar had to be within the stock length. The brackets are used backwards to accomplish this, and slightly into the curve of the bumper. But it fits, doesn’t add to the length and is very stout.
D6B11F17 074A 4DFD 96C1 4991F5902694
8256C8EC 21CD 46DA 9D9B A26C44AFED23
E500CBB6 6B8F 4E81 B3A7 B56D388B8F08
Russ989
Russ989
22,569
146,535
Reactions: Montecresto
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
Wow.
That would last less than 2 minutes where / how i ride.
Then again.........
Neither would the stock tires.
Reactions: Isaiah
34,174
Wow.
Then again.........
You’d better come up with an alternative mounting up there then buddy....👍
russknight
russknight
1,916
7,542
Perry Florida
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
True story.
Have you compared the light output to the stock high beams?
Probably gives you some more light on the sides.
I found after adjusting my headlight aiming up a little that the pair of 4” rigid hyperspots i had mounted up front did not help for distance at all.
Reactions: Isaiah
russknight
russknight
1,916
7,542
Perry Florida
No, I’m waiting on a harness from Richard now, it will be off a dedicated switch from keyed power.
I have a smaller one installed utilizing the high beam harness. I'm going to swap it for a 20" one.
208,013
Wise choice, my 20 inch Black Oak is too bright to use riding behind some one, bought some Xprite mirrors with lights built in for side vision, I hope there not too bright!
Reactions: russknight
34,174
I could see tying it to the high beams...👍
34,174
Yep, that’s always my main concern. My light bar is pointed slightly down for that reason. Don’t know that one can totally immunize the rider in front of you from your auxiliary lighting though. I just adjust my mirrors accordingly when night riding with others.....
russknight
russknight
1,916
7,542
Perry Florida
I've got a pair at the store. Let me know how you like them.
208,013
I haven't rode behind any one yet, I think they will work, there pretty bright though?
208,013
Have you tried the lights out yet?
Yes around in the yard and down the road stuff, side vision is great, with the head lights on I have blind spots on hard corners, these will cure that, just hope I can run them behind another rider.
34,174
Had this custom made on its way from the club store. It plugs into the blue OEM plug under the hood and will provide triggers for three keyed power accessories including the light bar I just installed.
EB45F558 DADE 4545 BAB4 0DAAB5FD5A4F
