5 7/16x20 1.5” bolts for the lap belts and I grabbed bunch of the 7/16 thick washers they call them.What size bolts did it take?
The passenger head rest I grab 7/16x20 2.5,& 3.0 think the 2.5 I ended up using Everything came from True Value
On the passenger side you want to stack a couple of the large think washer so it holds the solder strap ends away from the back of the head rest so you have enough room to adjust the length of the straps with out having to loosen the main bolt and everything.
