P1000m5 2017 1000-5 PIONEER LE by UTVMI
utvmi
utvmi
265
574
What size bolts did it take?
5 7/16x20 1.5” bolts for the lap belts and I grabbed bunch of the 7/16 thick washers they call them.
The passenger head rest I grab 7/16x20 2.5,& 3.0 think the 2.5 I ended up using Everything came from True Value
On the passenger side you want to stack a couple of the large think washer so it holds the solder strap ends away from the back of the head rest so you have enough room to adjust the length of the straps with out having to loosen the main bolt and everything.
utvmi
utvmi
265
574
Getting some trail time and mostly dirt roads in today...:)
Stopped back by the house to refuel
2017 08 12 135907
utvmi
utvmi
265
574
Trail time?! It looks so clean!
That was early on we put on 150 miles today mostly dry seasonal roads and dirt roads and some paved, Now I have to do that 100 mile service lights on and its back in garage , will power wash tomorrow and see what all that service includes.
Here a little more dirty for ya...:D
2017 08 12 205721
E
elkguide
3,377
7,963
Vermont
Looking good especially with the mud camo!
Reactions: utvmi
utvmi
utvmi
265
574
I know a lot of people are having clutch issues in their rigs, I wonder if they are using the wrong oil, Did some reading last couple of days and the Pro Honda GN4 4 Stroke oil is listed as an MA oil
In 2016 they went to the next level witch is Ma2 witch is higher level then the Original MA
So with that being said I will be going to Royal Purple Max Cycle 10w40 witch is MA2 oil for WET CLUTCHES, Thinking all theses other oils with different additive packages are possible issues with the clutch packs being theses machines are wet clutch setups. Just Thinking this and not saying its the cause...:)
There is a reason Honda's oil is MA
Everything I have found says MA2 is the Best oil for wet clutches.
Here a couple pdfs if anyone wants to read up more on MA2 oils for wet clutches...;)
  • TSB SE-2008-01-01 Wet-Clutch Operation and Lubrication Requirements.pdf
  • 4T_EV_LIST.pdf
Reactions: Dp5hunter
utvmi
utvmi
265
574
Oil made the trip, Got to love Amazon Prime.
Here is a pic of the back, Not sure if there is any other MA2 wet clutch oil on amazon but I run Royal Purple and Mobil One in a lot of things I own, Couldn't find a mobile one with the MA2, maybe I missed it but anyways this what I'm going to be running and hopefully no clutch slipping...o_O
2017 08 16 090604
156,225
I have an '07 little 4 cyl. with 310k...Royal Purple's good sh**!
utvmi
utvmi
265
574
Mudbuster XL front and backs arrived yesterday, Took tires off to make install way quicker, They are super nice and will stop all that spray from the tires, and I get a lot with the 2" spacers...:D
2017 08 25 102910
2017 08 25 102933
2017 08 25 102928
2017 08 25 102902
2017 08 24 205130
2017 08 24 205120
E
elkguide
3,377
7,963
Vermont
I don't see ANY mud on them...........................
Similar threads
